View Poll Results: January 2013 - Rotary Of The Month
one320fc's 1983 RX-7 FB Series 2 Limited Edition 4 21.05%
9krpmrx8's RX-8 Touring 2004 3 15.79%
FC Zach's 1976/77 Hercules W2000 6 31.58%
rx7 vinnie 1987 RX-7 13b Fungus Growing 4 21.05%
chibikougan's little gem 1 5.26%
RotaryMachineRx's RX-8 1 5.26%
N.RotaryTech's FC 0 0%
Voters: 19. You may not vote on this poll
Old 01-02-2013, 02:27 AM   #1
ZGN
Administrator
ZGN's Avatar
Vote for January 2013 "We're still here" Rotary of the Month!
Happy new year everyone!
Vote on your favorite rotary for Jan car of the month.
Ends in 4 days vote now!
one320fc
64k original miles I'm the second owner, currently being restored.
Fresh Coat of paint.
Holley 465, road race headers, 3 row aluminum radiator.
9krpmrx8
Mazda RX-8 Touring (6 Speed MT) built 07/2003 currently with 134,000+ miles.
Engine: Pineapple Racing Ported Engine with stage 2 oil mods, BHR 3" midpipe, Turbo XS 3" catback exhaust, Custom Oil cooler setup with a Perma Cool oil thermostat and custom lines, JEGS recirculated catch can, SOHN adapter, Racing Beat Air Pump block off plate and air pump deleted.
Cooling: Mizu Aluminum Radiator, FAL 220 dual fan/shroud setup, custom aluminum under tray, custom mounted Derale secondary radiator setup with fan, Mazmart RE-medy Water Pump, Mazmart RE-medy Thermostat.
Fuel/Ignition: BHR Ignition and BHR fuel pump.
Forced Induction: Cobb Tuned by yours truly with training by Kane @PPo2performance. Greddy turbo kit with fixes, upgraded turbo by Comp Turbo with a water cooled CHRA, 56lb/min, upgraded hot side, Comp Billet Aluminum Compressor wheel, Custom cooling lines, oil feed line, and porting of the compressor inlet and outlet pipes by SARX. Custom intake setup with SARX filter, Synapse DV, and Grimmspeed Boost controller.
Suspension/Brakes: Hotchkis sway, Stance Coilovers with Swift springs (9kF/6kR), Stop Tech BBK with ET500 pads.
Interior: Cobb mount by proclip, dual vent pod (fuel pressure and oil pressure), Lotek center pod (oil temp, PLX multigauge, Boost), full interior LED kit, SARX embroidered floor mats, Good Box integrated into factory head unit face, Factory Bose with ipod integration and a 10" bazooka bass tube, Voo Doo shift knob, black leather boot with red stitching, Zeta arm rest pad, CF Door sills,
Wheels/tires: Volk GTS 19x8.5 F and 19 x 9.5 R. EVO R 255/35-18 R and 245/35-18 F
Exterior: New HID headlights with Xpel film, Shaved emblem on front bumper, AP lip, RFX side vents, Lebren rear rotary LED, LED 3rd brake light.
Waiting to be installed (soon): Advanced Keyless system, Mazdaspeed Front bumper, burnout sides, AP rears, Hotchkis front sway and endlinks, BEGI vacuum block/vacuum reservoir, Corksport strut bar, rear dampener adjusters, and BHR intake tray.
I am sure I have forgot quite a bit.
I need to get an updated pic showing the battery relocation and new coolant reservoir.
QuT347hgnMg">QuT347hgnMg" type="application/x-shockwave-flash" width="425" height="350">
FC Zach
1976/77 Hercules W2000 w/ oil injection, one of 199 ever made!
This picture was taken at DGRR 2010
I bought the bike from Jess @ Rotary Recycle a few years ago after selling my RE5. Since owning it I've gone through everything and made sure everything worked.
The only parts replaced on the bike are the clutch discs (OEM) and a new battery (Odyssey drycell). That I know of, the bike is original.
With a little polish and time she'll clean up nicely!
These clutches are a PITA! The transmissions were KTM special built trannys and the clutches are a disaster! These would grab, straight from the manufacturer. I experimented with mine by using a combination of fiber and brass plates and also different types of fluids (ATF, standard gear oil and many others). The results were better but not anything to brag about, basically a lot of work for nothing
All loaded up and ready for the show
rx7 vinnie
87 RX-7 13b-re Cosmo that is growing fungus.
Purchased for $500.
Ground some rust off it to store it until I could get at the project. Ended up being my main project at the moment. Budgeting and trying to get some room in my shop as to not burn the place down while doing some welding.
Interior
Glamour shot w/flat that magically has fixed itself
Mods it came with:
Big Swaybar
Racing beat sway bar spacer blocks.
Rusted out gas tank.
Getting all chassis work done first.
Looking at solutions for a few things.
Going to get a rewire most likely.
Parts collected so far:
My 13BT from my FC is going under the hood
Sparco steering wheel
HKS Titanium Muffler
Supernow Bushings
Basic description of build:
- GReddy Rx8 Turbo Kit w/ custom modifications
- GReddy Front Strut Tower Brace
- GReddy PRofec B-Spec II Electronic Boost Controller
- GReddy SE 3" Catback Exhaust
- GReddy Feed Oil Filter Adapter
- HKS SSQV BOV
- Black Halo Racing 3" Resonated Midpipe
- Agency Power Underdriven Crank Pulley
- AEM UEGO AFR Gauge
- Revolution Fuel Pressure Gauge
- Autometer Mech. Boost Gauge
- Cobb AccessPORT with Custom Tuning by MazdaManiac
- RaceRoots Carbon Fiber Oil Catch Can
- Tein S-Tech Springs
- Hawk HPS Front & Rear Pads
- Walbro 255lph Fuel Pump
- Seibon Carbon Fibre Hood
- Ecsta XS Performance Street Tires
N.RotaryTech's FC
HBP back in action. I love it.
This time I have every port on this motor ported.
Details:
S4/S5 hybrid motor with 9.7 comp rotors. Big street ports on all the irons with thin-but-long bridge ports on the end irons. Mild street ports on the housings.
Full RB exhaust system.
Haltech e6k.
I think I'm running 720cc injectors for the secondaries.
No emissions, no A/C, no PS, no afm.
CM Stage 2 carbon kevlar clutch.
Koyo Rad.
Kevin
Old 01-02-2013, 03:51 AM   #2
chibikougan
chibikougan's Avatar
Had to go with Hercules Hercules Hercules!
Thanks Kevin
Old 01-02-2013, 12:09 PM   #3
estevan62274
counting down till DGRR
estevan62274 is on a distinguished road
Thumbs up
^Same here
Hercules W2000 FTW!
-74 RX-4
-84 REW GSL-SE
Past rides
-05 REW Swapped RX-8
-93 FD base
estevan62274 is offline   Reply With Quote
Old 01-11-2013, 12:40 PM   #4
9krpmrx8
SARX + Boosted = Win
9krpmrx8 is on a distinguished road
I just installed a Racing Brake BBK
9krpmrx8 is offline   Reply With Quote
Old 01-12-2013, 09:01 PM   #5
Sephitrask
BOILED PEANUTS!!!
Sephitrask's Avatar
Sephitrask is on a distinguished road
NIce brakes Scott!
www.rotarycarclub.com
"The way a Rotary engine makes power is ferocious, much like having a chainsaw under your right foot."
Sephitrask is offline   Reply With Quote
rotary of the month, rotm
