Old 12-29-2012, 05:56 PM   #1
kimbo305
kimbo305 is on a distinguished road
FC gas pedal widening options?
Hey, all.
What are the latest options for widening the gas pedal? The way I sit in the FC, my right leg is bound up a bit by the wheel, and I can't swing my heel as easily for heel-toe.
I'm looking for a decent option for widening the gas pedal. I found this initially:
Autovation Technologies
I'm not really looking to replace the whole set for grip or anything, though. Just the gas pedal, which that doesn't seem to widen that much.
I was wondering if the NA/NB Miatas had the same gas pedal as the FCs? If so, I could use this:
Flyin' Miata : Interior : Ergonomics : FM gas pedal extension
And it'd be a more reversible install.
kimbo305 is offline   Reply With Quote
Old 12-29-2012, 11:02 PM   #2
Any number of (universal) pedal kits will work...
All of them should work.
There really isn't such thing as model-specific.
There are two basic types:
1) bolt-on, usually with screws / bolts and straps of metal
2) screw-on, drilled and screwed into your existing pedals
Both types are basically "removable."
I prefer Razo brand pedal kits.
http://www.carmate-usa.com/html_razo...ort_pedals.htm
Old 12-29-2012, 11:10 PM   #3
kimbo305
Only issue would be the size of the base you're screwing into, right?
From what I can tell, the FM cover and the Autovation set have the same slant and hole spacing.
Old 01-01-2013, 02:43 PM   #4
EJayCe996
PPP-P-P-P-POWER!
EJayCe996's Avatar
http://www.srpracing.com/default.cfm
same as autovation, about $30 cheaper all options being equal (minus the titanium option as they don't do that) unless you've got a GOOD discount code.
2. Say you love dubstep
3. ?????
4. PROFIT!
Axiomatic: Total cacology.
