Old 12-24-2012, 12:04 PM   #1
JDriftM
Dedicated Rotorhead
JDriftM is on a distinguished road
Smile The Unofficially Official: To-Do List Thread DGRR 2013 Edition
Lets get it going, post up your post-holiday lunacy plans for your car(s), trucks, bikes, whatever.
I will be posting my list in a little bit, but I will just start with:
-engine build
-EMS install
And I'll ask the burning question we all always have;
What do you have NOT planned but are going to freak and do before DGRR, Brian?
DGRR 2013.
JDriftM is offline   Reply With Quote
Old 12-24-2012, 12:59 PM   #2
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
OK, I'll play. Lets seee...
1. Replace rear suspension with full 3 link (in progress).
2. Fit and plumb new Cobra R brake system (sort of in progress)
3. Replace front suspension with Kenny Brown subframe and figure out how to fit front upper unequal length control arms.
4. Make the wheels I bought actually fit. (thus 1 & 3)
5. Annddd make it all look presentable before DGRR.
Just a short little list, nothin' to it.
Old 12-24-2012, 08:57 PM   #3
banzaitoyota
banzaitoyota is on a distinguished road
Paint drivers side of car
Reroute exhaust
Rad and oil cooler mounts
Find 13" street tires
Windshield wipers installed
My deuce
banzaitoyota is offline   Reply With Quote
Old 12-24-2012, 11:40 PM   #4
reddozen
Gold Wheels FTW
reddozen's Avatar
Kick the RX7 and tell it to finish itself!? Sadly, it'll be a couple years till my FC is where I want it. At least I have the 8 for now.
Guess I can play seriously...
Replace transmission
Replace SSV valve
Replace throwout bearing
Replace end links
My Cars:
1974 RX4 Coupe
1991 FC3S RX7 - Sold
Old 12-25-2012, 12:58 AM   #5
willnordacgreen1211
willnordacgreen1211 is on a distinguished road
shortblock swap, mount and paint body kit, new wheels and tires, maybe APR wing.
willnordacgreen1211 is offline   Reply With Quote
Old 12-25-2012, 07:01 PM   #6
I'll play.
RX-8
1) sell it
Cosmo
1) rebuild brakes
2) rebuild rear differential (bearings/seals)
3) rebuild carb
4) rebuild front bearings/seals
5) new fluids
6) e-fan
7) upgrade alternator
8) upgrade ignition (electronic)
9) fix some rust
10) tires
Hope all this works so I can drive it to DGRR.
Otherwise
1) put gas in the Speed3
Old 12-26-2012, 11:56 AM   #7
Why do I always get mentioned for these things???? OK... lets see...
'98XJ - Official Rotary Support/Tow Vehicle - Northern Chapter
Fixed Yoke kit and new diveshaft
Install new flywheel
Install New ACT Clutch
ReGear both axles w/3.55 gears
Some sort of locker in both Axles... would love to do an ARB airlocker but I need to see if it's compatible with the 3.07 gear in the axles now because I have bigger plans
Install tranny/t-case
Battery tray and jumper leads... this is a ROTARY support vehicle afterall
A little rot repait - this may wait till next winter when I "freshen" the paint
Build Rock Rails
I'd LOVE to have an ARB front bull bar so I can build a reciever hitch for it... mmmmmm moving trailers from the front of a vehicle....
Electronic trailer brake controler; again.. because ROTARY
Build rear hitch basket
Rear cargo shelf and divider and tool box
Diamond plate roof top storage box
'88 FC - You all know this thing
Build new exhaust mani
Build new 4" exhaust from mani to bumpers
Fix broken center panel
Repaint bumper (yearly thing) and both fenders
Bigger dual oil coolers mounted in a different location
Redo brake ducting
Re do engine and aux harness
Meth tank
Overflow tank
New sub - Levi
500hp dyno sheet
'04 FE
Build new custom SS 3" exhaust from RB header back
Find and kill clunk in the front end
Wire in sunroof module for auto-close
2 subs in center pass thru
rear-view camera??
'Vert
Finish engine harness
Build W2A intercooler
Install rebuilt rear
Install rear suspension bushings
Wire up the entire car
build w2a water tank
... ya know what.... this is easier... BUILD ENTIRE FUCKING CAR
Old 12-26-2012, 12:46 PM   #8
banzaitoyota
This begs the question, do I tow the duece up there. Remember my clutch change out in 2007 in the parking lot:-)
My deuce
Old 12-26-2012, 12:48 PM   #9
That's why I'm bringing my Jeep.... any major problems... on the trailer she goes... jump in other rotary, have fun....
Old 12-26-2012, 01:06 PM   #10
I remember that.....well I remember driving by as you guys were working on it.
We stopped and asked if you needed help, but you can only fit so many dudes under an RX-2. Lol
Old 12-26-2012, 01:31 PM   #11
2gslse
My list depends on car driven:
FD : change oil, coolant , kick tires add gas and enjoy.
FB : pick the car up find tires/wheels to use the available HP, fix steering, detail car should fix trans and add USDM 5th gear instead of JDM one in it that SUCKS.
2006 VW TDI commuter
Old 12-26-2012, 01:44 PM   #12
GySgtFrank
GySgtFrank's Avatar
Getting enough tire under there for that beast is going to be a challenge.
Old 12-26-2012, 01:53 PM   #13
2gslse
Should I pack extras???
Old 12-26-2012, 02:18 PM   #14
banzaitoyota
Where are you finding 205/13's?
My deuce
Old 12-26-2012, 02:23 PM   #15
GySgtFrank
GySgtFrank's Avatar
Yours?
At least they'll match your Centerforce clutch disc.
