Old 12-17-2012, 05:33 PM   #1
magpiemini
magpiemini's Avatar
magpiemini is on a distinguished road
Fuel Pump Issue GSL-SE
Ok, I have searched high and low to find an after market fuel pump that matches to one in my 1884 GSL-SE. The one in the car has a banjo fitting on the outlet that is secured with the pressure regulator. This banjo fitting allows the outlet pipe to do a 180 to go back to the stock filter.
All the ones I have found look close but they do not use a banjo fitting. I have not found a hose fitting to attach to those threads.
Any love here?
1984 RX7 GSL-SE
Building for the 24 Hours Of Lemons
magpiemini is offline   Reply With Quote
Old 12-17-2012, 07:28 PM   #2
magpiemini
magpiemini's Avatar
Never mind, I see how it works now. All of the ones I have looked at will work with the banjo fitting. I was expecting a hole in the fitting on the pump. The fuel passes into the regulator and back into the banjo fitting. Guess I had better get a new pressure regulator too.
1984 RX7 GSL-SE
Old 01-07-2013, 09:18 PM   #3
diabolical1
I have radioactive semen
check your FSM. i don't think they came with fuel pumps that year. i think they used boilers for charcoal. they're NLA from Mazda, so Ebay might be your best bet.
okay ... you know i had to, right?
seriously though, i'm glad you got sorted out, bro.
