Old 04-11-2008, 01:52 AM   #1
TheDriver216
TheDriver216's Avatar
Brake Problems..
Well the other day i changed pads etc etc and a new right front rubber line.. now i bled the brakes properly, farthest away etc etc.. now ive had to re bleed them twice since then. It seems to stay firm for a few days then all of a sudden ill lose all pedal. Then when i rebleed them the right front seems to always push out a ton of foamy fluid before i get straight fluid with no air bubbles in it. What can cause the foam issue. everything seems to be tight and im not losing any fluid.
Old 04-12-2008, 04:01 AM   #2
81gen1
81gen1 is on a distinguished road
maybe a hole in the line. check your lines, also using the wrong fluid made a weird jelly foamy stuff in my motor bike.
1988 GXL-White
1985 GS-Red
1984 GSL-Primer
1983 Limited Edition-Champaign Silver-Full Suspension, Konig Rewinds
1982 GSL-Charcoal Grey-Weber 45, RB SP Exhaust, MSD Direct Fire
1981 GSL-White
1981 GS-Red, IMSA widebody, 3 piece Epsilons, Custom Exhaust
1981 GS-Blue
1980 SA-Black
1979 SA-Black Dragon Bodykit-White 12A Bridgey Turbo project
81gen1 is offline   Reply With Quote
Old 04-12-2008, 11:31 AM   #3
TheDriver216
well im using standard dot3 fluid.. and its only the front passenger that is giving me the foamy stuff... and im not losing any fluid ... i dunno could tthis mena the master cylinder or brake booster is toast?
Old 04-12-2008, 03:08 PM   #4
Kentetsu
Kentetsu's Avatar
If you lightly hold the brake pedal down, does it slowly sink to the floor?
Old 04-23-2008, 09:19 PM   #5
djjjr42
djjjr42's Avatar
djjjr42 is on a distinguished road
Did you get this problem resolved?
djjjr42 is offline   Reply With Quote
Old 04-24-2008, 04:59 PM   #6
josh18_2k
im guessing you have a leak somewhere in the caliper. might be time to rebuild them. it is a 20 year old car after all.
if they leak past the pistons, then i would guess you'd never actually see the fluid.
Old 04-24-2008, 07:44 PM   #7
TheDriver216
yeah i changed the master cylinder.. all better now
