Old 11-13-2012, 08:17 PM   #1
IH8DSM
IH8DSM's Avatar
Ih8dsm going turbo
Ok haven't posted in a long time but here's my build thread. I'm hoping this will be done by dgrr but well see if I can get it built and tuned by then.
Here's the basics
85 gsl-se
Fender flares running 15x8 0 offset xxr
Re-speed race coilovers
2nd gen trans
Light weight flywheel
Exedy stage 1 clutch
Racing beat stage 1 pressure plate
Right now it's a Carbd turbo motor running na.
So here's the build specs
-cryotreated apex seals
-cryotreated corner seals
-Atkins side seals
-rx8 e-shaft with oil jet mod
-lightened flywheel
-garret 60-1 84ar
-tial 60mm wastegate
-tial bov
-s4 rotors
-s5 turbo motor
-s5 turbo bearings and oil pump
-1600cc and 2000cc injector dynamics
-aeromotive a1000 fuel pump
This is my trying to decide List
- the grannyspeed 8.8 rear end
-run a trigger wheel
- which haltech to run
- if I need to go up to 15x9 or even 15x10
- still trying to figure out the clutch as well thinking a sprung 4 or 6 puck
Ill start posting pictures as I start getting more deeper into the build
I'm sure I forgot something's that I have or will be doing but ill add those later
