Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > BNR Turbos
BNR Turbos www.bnrturbos.com (AL) Custom and rebuilt turbochargers
Old 04-10-2008, 03:55 AM   #1
AwakenNoMore
AwakenNoMore's Avatar
AwakenNoMore is on a distinguished road
s5 hybrid questions
I'm thinking about sending my s5 core in what exactly is done during the upgrade besides internals? Cleaning? speacial hotside coating? any broken bolts replaced?
Do you port the wastegates of the s5 turbos? If so how big? Can the back plate be milled for further WG travel?
1993 VR Touring, motor built by Arizona Rotary Rockets.
AwakenNoMore is offline   Reply With Quote
Old 04-13-2008, 10:49 PM   #2
Bryan@BNR
Bryan@BNR is on a distinguished road
I can port them a lot. I don't suggest a lot of porting if you are wanting to run 15 psi or more. The bigger the port, the more the boost wants to fall off at the top.
I can mill the cover for further extension if you want it. A rebuild and upgrade is all cleaned up and fully inspected before used. Only parts remanufactured in the center housing rotating assembly of the stage 2-3 is the shaft and the bearing housing. The rest is upgraded and replaced. The stage 4 the whole CHRA is new.
If you have broken bolts, I can handle removing them.
Bryan@BNR
205 640 1193
Bryan@BNR is offline   Reply With Quote
Old 04-15-2008, 03:18 PM   #3
AwakenNoMore
Cool i will definitely be using you for ALL of my turbo work Bryan! Thanks for taking time to answer my questions.
- Jared
Old 04-15-2008, 11:44 PM   #4
Bryan@BNR
no problemo!
Old 04-21-2008, 01:42 AM   #5
AwakenNoMore
will you rebuild hybrid turbos if they aren't your hybrid? i got one cheap and the inside of the hotside has oil or something seeping out of it
Old 04-22-2008, 10:52 AM   #6
Bryan@BNR
I can. The rebuild starts at $325 and goes up from there if I have to repair or fix existing problems with machine work/balancing.
Bryan
