Old 10-21-2012, 10:19 PM   #1
RICE RACING
Don Mega
RICE RACING's Avatar
Exclamation FS: Blitz SBC I-Color + input harness!
Control up to 2.5bar gauge boost pressure
Best Boost controller on the market period!
Calibrated to show true rwhp as well
Comes with custom input harness so the unit is a mini data logger as well!
can log boost, AFR, EGT front and rear, power, fuel pressure (use your own sensors)
Amazing unit !
Full boxed AS NEW, English Instructions! New silicon hose! and will throw in silicone heat sleeving as well!
+ full set of set up notes for Tial V44 waste gate set up.
$1500 shipped
PERFECT BOOST CONTROL! Boost to speed, Boost to RPM, 4 stages, Full Auto or Manual set, this is proven to be the best you can get!
No hype! just true real results, if you need an add on boost controller that works this is it! and it is fully set up! ready to go!
www.riceracing.com.au
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 11-10-2012, 01:45 AM   #2
RICE RACING
Don Mega
sold
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 12-25-2012, 09:51 PM   #3
RICE RACING
Don Mega
BUMP, back for sale.
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 07-12-2013, 07:07 PM   #4
RICE RACING
Don Mega
bump
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 07-27-2013, 03:58 AM   #5
RICE RACING
Don Mega
This bad boy is in its original packaging and in tip top condition, its set up to run and everything configured correctly all you need to do is fit it up and BOOST AWAY!
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 09-07-2013, 12:19 AM   #6
RICE RACING
Don Mega
BUMP this, as you can see its all as new.
English instructions and ECU wire up guide for all Jap cars.
This is set up and ready to go ........
Will include 6mm push fitting for your intake manifold so its all plug n play, also custom input harness I made so you can log EGT, fuel pressure, etc as per pics in my RICESP!
This is the best unit around!
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 09-26-2013, 07:52 AM   #7
RICE RACING
Don Mega
sold!!!
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
