Old 10-11-2012, 12:17 PM   #1
Garfinkles Motor Works
air pump replacement idler
As most of you know ,if you remove the air pump the car needs to have an idler in its place to keep the belts from pulling on the crank and wearing the crank bearing .I have several adjustable idlers left .If you need more info see the venders section under Garfinkles Motor Works .Due to the high cost of the double row bearing and having the pulley CNC cut I will not be making more of these . First come first served. PM me before sending paypal to be sure I have one for you .
Old 10-29-2012, 12:28 PM   #2
I have two more to sell ,PM me befoer sending any money to be sure there is one for you .
