View Poll Results: November Rotary of the Month - SevenStock 15
13x's Early SA - Was on the way and looked great on the trailer but didn't make it 4 18.18%
DivinDriver's SA - So clean you can eat off of it! 15 68.18%
Alex Rodriguez's FD - Glad someone took at least one photo of his car. 3 13.64%
Voters: 22. You may not vote on this poll
Old 10-11-2012, 01:46 AM   #1
ZGN
Administrator
ZGN's Avatar
November SevenStock 15 Rotary Of the Month Voting
13x's Early Production SA
"was on the way and looked great on the trailer but didn't make it"
SinCityRotary
Mod list not provided. (Send it to me and I'll list it here ASAP!)
DivinDriver's RX-7
World's Oldest Newb
Polished/Painted Engine and Trans Bellhousing
January to June 2012 Complete Engine & Carb Rebuild (Stock Specs)
Hand-Sewn Custom Interior
Factory-Option 13” Aluminum “Waffle” Wheels
Blaupunkt Speakers
Electric Window Conversion (from OEM Components)
Electric Mirror Conversion (from OEM Components)
Energy Urethane Sway Bushings
Rear Storage Bin Conversion (from Modified OEM Components)
AutoMeter Gauge Package, w/Custom In-Console Mount
Mazdatrix Silicone Vacuum Lines
Moog Heavy-Duty Idler Arm
Pilot Vintage Fog Lights
Racing Beat Type-II Oil-Gauge Adaptor
Racing Beat Silicone Radiator Hoses
Racing Beat Braided Stainless Brake Lines
Racing Beat “Old School” Steel-Boot Ignition Wires
Racing Beat Braided Stainless Oil-Cooler Lines
Racing Beat Springs
Racing Beat Oil Fill Cap
Redline Leather Shift and E-Brake Boots
ReSpeed Braided Stainless Clutch Line
ReSpeed Billet Thermostat Cover
Rotary13B1 Billet Clutch and Brake Fluid Caps
Tokico Shocks, KYB Struts
Alex Rodriguez's FD
Suspension-----
Stance GR+3w/External reservoirs
Suspension Techniques front sway bar
Racing Beat front lower swaybar mount brace
Engine
Large streetport ,ALS seals, Atkins solid corners, full Mazda OEM spring and seals kit, Rotary Aviation coolant seals,orings and oil control seals.
Silicone vacuum hose conversion
OMP delete kit including drive gear for less strain in front assembly
M2 Performance lightweight aluminum flywheel
B and M short throw shifter
ACT HD PP +6 PUC
New pilot bearing and seal
Turbo-----
Garrett TO4z
gt35r compressor wheel
.70a/r compressor
4” diameter compressor inlet
.96 hotside
polished compressor
HKS 304 stainless exhaust manifold
Tial 40mm wastegate 1.0 bar spring
HKS blowoff valve
Custom engine compartment turbo heat shields
Custom intercooler system made By GARRETT
12 x 18 x 3” (H/W/T) Garrett core w/ custom fin sets
Slant mounted (for max size, space, and performance)
Custom cold-side air ducting using original factory air supply duct
Custom sheetmetal end tanks
2.5” intercooler plumbing
12” Spal draw-through fan
Custom cold air intake system
Sealed aluminum airbox w/ DEI reflecta gold
Nose/under-car air source
K&N cone filter (6” max diameter)
4” duct from air box to compressor inlet
Custom oil cooler system
Dual 19-row Setrab oil coolers
Mocal oil thermostat
-10AN SS braided lines and fittings
Parallel plumbing configuration (for max effectiveness and min pressure drop)
Mazdaspeed oil cap
Rotary13b1 brake cap
Cooling system-------
MazdaComp aluminum race radiator
185º thermostat
FC thermoswitch (changes fan switching temp from 226 to 203F)
Auxiliary electric cooling pump (to prevent hot shutdown heat soak)
Air separation tank (AST) removed
Cooling fan relays rewired to eliminate low speed operation
4 vent carbon fiber Knightsports extractor hood (to reduce underhood temps)
Greddy water pump underdrive pulley (to prevent high speed cavitation)
AC system removed
DEI reflect -a-gold on intake box, radiator,and lim uim
Custom exhaust----
3” v-band downpipe (w/ shielded flex section open dump pipe)
3"to 4" stepper
TRUST 4" mid pipe Rare!!!
TRUST 4" MID PIPE BACK Super mega exhaust
TRUST V-band-clamp connections
MANAGEMENT-----
APEXI power FC
APEXI commander
LS2X YUKON coils with individual built in igniters
Fuel
Cj motorsports primary rail
Rx7store secondary rail with fuel temp bung
Bosch 1680 cc secondaries
Injector dynamic 1000cc primaries
Aeromotive FPR
Summit Racing -8AN 40 micron filter
Summit racing fuel gauge
JEGs y-block
Russell Y-block
BOSCH 044 in tanks
-8 FEED nylon braid lines with all hardended fittings
Brakes-----
Brembo front rotors
Goodridge SS braided lines
Motul 600 fluid
Hawk Blue pads (track only)
ABS- Delet kit - earl/xrp fittings in braided lines
SSBC proportioning valve
Gauges
Prosport boost gauge
Prosport oil pressure gauge
Prosport water temp gauge
Prosport 60mm triple center pod
INNOVATE Timer wideband AFR w/digital display and datalog to TEC3
INNOVATE LC-1WIDEBAND LAMBDA
HKS turbo Timer
Afc hand held
Other-----
Magnecor 8.5mm plug wires with MSD ls boot ends
Bosch battery relocated behind passenger in storage bin
Custom hidden trailer hitch (used to tow race tires to track)
Greddy alternator pulley
Greddy underdrive pulley
Greddy water pump pulley
Custom aluminum catch can
Greddy aluminum intake elbow
INTERIOR
RECARO Spirit R seats
recaro reclining seat rails
AUTOPOWER 6 point cage
MOMO veloce 20yr old vintage race wheel with RARE red Horn
miata wheel hub
NRG quick release
FULL BLACK INTERIOR CONVERSION
broadway mirror
glass sunroof
3 over ride switches for external water pump, radiator fan, intercooler fan
Pioneer avic 1double din
Kicker DS 6x8 mids
Kicker DS Tweeters
Kicker DS crossover,
Alpine small 1000watt amp
JL audio w6 10" subwoofer
Custom Fiberglass enclosure built by me
JDM arm rest
TRUST shift knob
EXTERIOR---
VERTEX bumper
VERTEX side skirts
RE Amemiya rear CARBON track Diffuser
RE Amemiya gt3 wing
Knight Sports vent hood
Uras turn signals
Converted 99 tails
4 prong LED bulbs
Glass sunroof
RE Amemiya sleek lights,evo r 90 mm HIDs
WHEELS-
Work Equip
18x10 +22 Front 18x11 +22 Rear
TOYO R888 race tires
285-30-18
255-35-18
Project KIcs r22 lug nuts
I love Rotarycarclub.com 10points!
Kevin
Old 10-11-2012, 08:50 AM   #2
t_g_farrell
Waffles - hmmm good
t_g_farrell's Avatar
SAs FTW!
DD your car is looking great!
Old 10-14-2012, 02:26 PM   #3
DivinDriver
World's Oldest Newb
DivinDriver is on a distinguished road
Ray, I'm looking forward to WHiV next year,so I can get a close look at all the work you've done since SSXIV.
Alex, my car says that when it grows up it wants to be just like yours.
DivinDriver is offline   Reply With Quote
Old 10-14-2012, 11:07 PM   #4
13x
SinCityRotary
13x's Avatar
13x is on a distinguished road
it's been a bunch but still long way from ole beastie
WHiV8 in the works!! May 2015
Email
13x is offline   Reply With Quote
Old 10-16-2012, 01:22 PM   #5
DivinDriver
World's Oldest Newb
Well, The Beastie had a head start...
Old 10-19-2012, 12:41 PM   #6
13x
SinCityRotary
13x's Avatar
Hey DD do me a favor and vote for my car cause your car is kicking my cars butt
lmao
Email
Old 10-19-2012, 03:16 PM   #7
DivinDriver
World's Oldest Newb
But then I'd have to put up with my car bitching at me for weeks about me not loving her anymore... You've no idea what she put me through when I brought the Z home!
You know how the pretty ones can be...
Old 11-13-2012, 01:21 PM   #8
Red Baron
Red Baron's Avatar
Red Baron is on a distinguished road
Thumbs up
Late vote, but DivinDiver gets the cake.
Red Baron is offline   Reply With Quote
