Old 09-12-2012, 04:36 PM   #1
8_2blue
8_2blue is on a distinguished road
FB gsl lights will not work need help stat
so i'm having issues with my fb, i was putting in a new wheel in the end i mixed up the wipers and the light plugs, got that sorted out now i'm having more issues
the wipers work correctly before they were on all the time (when i was mixed up )
now that is correct my headlights don't function, running lights work blinkers and hazards work but the lights will not go up nor turn on even when you hold the high beam back..... i have no idea whats going on here
is there a relay i'm missing that could have been fucked ?? please any advice will be appricated
thank you
8_2blue is offline   Reply With Quote
Old 09-13-2012, 07:36 AM   #2
t_g_farrell
Waffles - hmmm good
t_g_farrell's Avatar
Check your fuses with a DVM. Could be ones blown from the plug mixup and its just hard
to see it.
Old 09-15-2012, 09:52 PM   #3
rxtasy3
rotary madness
rxtasy3's Avatar
rxtasy3 is on a distinguished road
check the fusible links, driver side by the battery.
rxtasy3 is offline   Reply With Quote
Old 09-19-2012, 06:47 AM   #4
Ranum
Ranum is on a distinguished road
now that is correct my headlights don't function, running led lighting work blinkers and hazards work but the lights will not go up nor turn on even when you hold the high beam back..... i have no idea whats going on here
thank you
If you are thinking of buying new lights you can go for LED lights.
Ranum is offline   Reply With Quote
Old 09-21-2012, 01:39 PM   #5
8_2blue
it ended up being a link, and i cannot find more so it looks like i'll be converting here shortly..
on another note to the led guy, i'm going to retrofit some projectors in there and see what i can come up with.. i do it in just about anythign else so i'm going to see what i can do somethign that is simple and classy and keeps the round lights and everything
Old 09-21-2012, 03:31 PM   #6
t_g_farrell
Waffles - hmmm good
You can get replacement fusible links at any autoparts place. These kind fit right in
perfectly.
Here they are at one store.
http://www.oreillyauto.com/site/c/de...=fusible+links
Old 09-21-2012, 08:35 PM   #7
8_2blue
thank you sir, rep for you, i never saw those either but i will look around for sure, all the ones i saw were inline fuses with wires but thats pretty sweet
