Old 09-06-2012, 01:16 PM   #1
Raksj04
I have Ultra power in me.
Raksj04's Avatar
Clunk in front of car.
I have noticed lately that when I hit the brake with about medium force while moving around 2-5 mph. I hear a loud clunk, thud, or whatever. I am not sure what could cause it. I do have godspeed coilovers, which have been on for about 6 months.
Old 09-06-2012, 01:42 PM   #2
brake pads moving in their holders? may need add replace shims/hardware, etc?
Old 09-06-2012, 03:23 PM   #3
MazdaMike
S4 Owner
MazdaMike's Avatar
MazdaMike is on a distinguished road
Yeah its the pads in the saddle, your missing shims.
1985 Mazda RX7 GSL 13B, Holley etc
1997 Mazda MX6 LS - DD lowered on 17s
MazdaMike is offline   Reply With Quote
Old 09-06-2012, 06:46 PM   #4
Raksj04
Raksj04's Avatar
Is it possible for shims to fall out of the cailper??
Old 09-07-2012, 05:00 AM   #5
Are you saying that the clunking started when you installed those cheap coilovers?
If so, did those coilovers come with either a rubber or silicone "isolator" to fit between the shock bodies and the coilover sleeve?
If not, then this is probably the problem...
The coilover sleeves will sometimes rattle against the shock body under transition loads on the suspension.
Old 09-07-2012, 11:06 AM   #6
MazdaMike
S4 Owner
MazdaMike's Avatar
That is another possibility. Shims cant fall out really if the pads are installed and everything is working correctly, but they can shimmy free and jam stuff up and make a shit load of noise.
Old 09-07-2012, 11:37 AM   #7
Raksj04
Raksj04's Avatar
the noise started out of the blue. I found a loose collar and tighten it up but the noise came back. I think I am going to get different coilovers later.
