Old 08-30-2012, 11:21 PM   #1
Mitchocalypse
Mitchocalypse's Avatar
Help me pick a wastegate
I would like some input as to which wastegate would be better for my setup. I want it to be as reliable as possible but not overkill. I want to order everything ASAP so a quick response + reason would be all I'm looking for. (I really don't know how to pick a specific wastegate.)
Turbo would be the ZN Performance garrett T04Z, with a 1.00 turbine a/r.
Long runner tubular manifold that comes with the kit,
3.5 or 3 inch downpipe (I'm not entirely sure.)
Anyways, the kit normally comes with the synapse 50mm wastegate, however i much prefer TiAL over synapse so that leaves us with the MV-R (44mm) or the V60 (60mm).
My goal is to make 500whp on approx. 21 psi of boost. If you need more info, I will gladly provide it.
Thanks!
Old 09-01-2012, 11:09 AM   #2
cewrx7r1
The Judge
I have a Tial 46mm and it is very good.
http://www.tialsport.com/prod_wg_pts.htm
Old 11-17-2012, 09:53 AM   #3
moenler
moenler is on a distinguished road
JGS gates are very good also. My last FD had a JGS 500 and it was great quality and solved the boost control issues I had with with a Tial 44mm. It uses an o-ring design instead of a diaphragm design as well.
http://www.jgsturbo.com/wgpg.html
moenler is offline   Reply With Quote
