Old 08-30-2012, 05:16 PM   #1
mattallac
mattallac's Avatar
rx2 rear shocks/ coil overs?
hello all , just started to work on my rear suspension and i was wondering if any one had any good ideas for rear shocks/coil overs. i have tokico hu3633 for an 86-92 rx7 and i was told they are to long ,so the hunt goes on .i just want to lower the rear 1.5 to 2 in .
Old 08-30-2012, 08:30 PM   #2
sen2two
KTEC
sen2two's Avatar
I have miata shocks with re-speed coilovers on my rx2. I can get you more info on that later if you want it.
what I have:
What I had:
Old 08-30-2012, 11:43 PM   #3
mattallac
mattallac's Avatar
that would be great , thanks. what kg springs are you using for the rear
Old 08-31-2012, 12:14 PM   #4
sen2two
KTEC
sen2two's Avatar
Suspension is Ground Control coilover setup with KYB GR2's. The fronts are are from a 1st gen with the spacers from ReSpeed. The rears are front struts from a NA Miata. Not sure on year though. This is how I got the car, so I don't have much info after that.
what I have:
What I had:
Old 08-31-2012, 02:59 PM   #5
Kentetsu
Kentetsu's Avatar
Check with www.re-speed.com
Old 09-01-2012, 01:09 AM   #6
mattallac
mattallac's Avatar
didnt find anything on re speeds site
Old 10-28-2012, 11:22 PM   #7
rx2fan
rx2fan's Avatar
rx2fan is on a distinguished road
lol probably a bit late but you can use FC rear shocks in a RX2
rx2fan is offline   Reply With Quote
Old 10-28-2012, 11:55 PM   #8
mattallac
mattallac's Avatar
not to late , but fc rear shocks are to long i have a new set . and they don't work correctly
Old 10-29-2012, 02:57 PM   #9
surem
surem is on a distinguished road
The have to be S5 FC rear... FB front with re-speed spacer
surem is offline   Reply With Quote
