Old 08-08-2012, 03:14 AM   #1
r4itei
r4itei is on a distinguished road
Jerky at 2500rpm only sometimes
like the title says, sometimes i start it and everything is peachy. sometimes it takes a few minutes of being jerky at 2500 rpm. when it gets jerky, i clutch in, let the car roll a bit, shift into a higher gear and wait til it reaches 2500. after the 5 or so minutes, everything is perfect throughout the whole powerband.
i'm not sure if jerky is a descriptive enough word. it kinda surges, or bucks... cant think of any other words to describe.
any ideas? im thinking maybe dirty injectors?
r4itei is offline   Reply With Quote
Old 08-08-2012, 09:00 AM   #2
Garfinkles Motor Works
Is the car stock with a stock computor if not what has been done ?
Old 08-08-2012, 10:10 AM   #3
r4itei
AFAIK, it's got a PFS exhaust, stock intake replaced by a short ram intake. cooling system has been upgraded to a koyo rad, it's got an FMIC.
computer is stock, i believe. i will ask previous owner to be sure.
Old 08-08-2012, 01:13 PM   #4
dexspeed
dexspeed's Avatar
dexspeed is on a distinguished road
Hmmm. I had a similar problem with an old E30 BMW. It turned out to be as simple as a clogged fuel filter. I'd start there as that's easy enough to do and does not take much time, then maybe start looking for vacuum leaks.
dexspeed is offline   Reply With Quote
Old 08-08-2012, 07:05 PM   #5
SINxSELEKTAH
Wait...wat?
SINxSELEKTAH's Avatar
SINxSELEKTAH is on a distinguished road
Fuel filters are the kind of thing that are rarely changed and always ignored.
SINxSELEKTAH is offline   Reply With Quote
Old 08-20-2012, 12:43 AM   #6
Speed of Light
Speed of Light is on a distinguished road
A worn O2 sensor can cause this problem too--the reason for this is that the ecu will set fuel trims based on what the O2 sensor reports as stoichiometric during closed loop operation. If the reported value is in error, all of the ecu's fuel maps will reflect that error, which may make the afr's marginal under some conditions.
No doubt the intake and exhaust mods have also affected the volumetric efficiency of the engine which requires compensation as well.
Hope this helps.
Speed of Light is offline   Reply With Quote
Old 11-12-2012, 06:38 PM   #7
jkstill
jkstill is on a distinguished road
As you see a number of issues can cause this.
For me it was TPS (Throttle Position Sensor) adjustment.
It was a different car after adjusting the TPS - no bucking at all.
jkstill is offline   Reply With Quote
