Old 08-05-2012, 08:08 PM   #1
vrracing
Rotating Assembly
Good target AFR for slow acceleration
We spent most of our time tuning for WOT but the car isn't smooth when slowly accelerating as it bucks a bit. Here is a Zeitronix log from the left marker to the right marker its about 7 seconds.
The rows are:
  • AFR
  • RPM
  • Vacuum
  • % of WoT
  • Narrow Band TPS in volts
You can see the closed loop mode until the second marker at which point I accelerated from 3000 to 5000 rpm. You can't see it from the charts but it didnt accelerate smoothly.
The AFR rose a little from closed loop from 14.7 to a bit less than 15. Seems like the AFRs should richen up, right?
Thanks
Old 08-28-2012, 06:37 PM   #2
Zak Rabbit
Zak Rabbit is on a distinguished road
You'll always get a lean spot on tip-in, what are you using to tune? Also, what method are you using?
Zak Rabbit is offline   Reply With Quote
Old 08-28-2012, 07:04 PM   #3
88turboii
destroy, rebuild, repeat
88turboii's Avatar
in open-loop vacuum, i usually tune to mid 13's AFR and it makes for pretty smooth acceleration, with quite a bit more power than if you kept it at stoich. it makes it feel a lot more torquey and responsive during acceleration. if you keep it lean, it will feel sluggish, imo. I have it come out of closed loop at 25% throttle
Old 08-29-2012, 08:26 AM   #4
vrracing
Rotating Assembly
Monday night we were going to fatten it up a bit at low load but first we wanted to reset the idle. So we set the ISC and disconnected the BAC, used the idle linkage stop to get the idle to around 775rpm and brought the TPS back to 1v (it was at 1.12 well within spec). Disconnected the ISC and plugged in the. BAC and were happy to see the rpms jump 200 or so when the a/c was turned on.
Then we went out to fatten it up (RTek2 for S5Tii and Zeitronix w/b) and it didnt need it; the transition out of closed loop was fine. The engine will still die if the a/c is on and he lets of the throttle suddenly from 3krpms or so but doesnt if the rpms are around 2k; which suggests we need to crank down on the dashpot (brand new as a couple of years ago).
Thanks for the tips.
