Old 06-07-2012, 12:44 AM   #1
bgarroyo77
bgarroyo77 is on a distinguished road
compatiblities
guy,
I have a 1985 GSL-SE RX-7 and was wondering is their and compatible engine parts from gen2 and gen3s ,and if so what are they?
Thanks
bgarroyo77 is offline   Reply With Quote
Old 06-07-2012, 07:58 AM   #2
t_g_farrell
Waffles - hmmm good
t_g_farrell's Avatar
They are all 13B engines, so yes. Maybe you have something specific in mind? Hard to say
without a target.
Old 06-18-2012, 08:41 AM   #3
cshaw07
cshaw07 is on a distinguished road
The gslse has the o rings in the housings where as the 2nd gen up has the o rings in the irons. you cant swap old school irons/housings with each other due to this.
cshaw07 is offline   Reply With Quote
Old 06-27-2012, 08:24 AM   #4
dexspeed
dexspeed's Avatar
dexspeed is on a distinguished road
Second generation transmissions will bolt up. There are other considerations that go along with that however.
dexspeed is offline   Reply With Quote
Old 06-30-2012, 11:56 PM   #5
lokirx706
lokirx706's Avatar
lokirx706 is on a distinguished road
Brakes with the Respeed conversion kit, engine bay fuse boxes, transmissions, engines, leading ignition coil from the FC for 2GCDFIS... Heck you can swap the front suspension from the FC if you have some time, and well the ability to do it. The rear suspension from the FC can swap as well. Keep in mind FB's are a solid axle and FCs are IRS so you need ALOT of fabrication ability.
Other than engines, and transmissions, not alot is 'plug and play' but it can be made to work.
lokirx706 is offline   Reply With Quote
