Old 05-26-2012, 03:46 PM   #1
schctrg
schctrg is on a distinguished road
Is my Eshaft usable?
Hey guys can I still use this eshaft it had rust on it and I decided to polish it off with some fine steel wool. Here's the result, if I can't use this can I use the rx8 shaft without switching the rear stat gear and modifying any oil passage? I will be building this engine with s4 rotors and s5 housing its a 6port. Thank you for your time. I also hope I can find all the nuts and bolts when I assemble the engine. Its my fear that I can't find everything =(
schctrg is offline   Reply With Quote
