Old 05-15-2012, 12:38 AM   #1
Daedalus704
Daedalus704 is on a distinguished road
V-Mount help
Hello RRC,
I'm in the process of doing quite a few things to my TII and this will include a V-mount setup. The one thing I need some help with concerns the intercooler sizing. I know that there will be plenty of room there after I remove the clutch fan and remount the radiator and ac. I was wondering what size cores any of you are using on you setups. I only want to hear from you if you either have or have had/designed a v-mount setup for the Fc3s. Pictures and suggestions are welcome.
Thanks
Daedalus704 is offline   Reply With Quote
Old 05-21-2012, 02:32 PM   #2
Sharingan 19
http://www.rotarycarclub.com/rotary_...ad.php?t=12917
Old 05-25-2012, 08:07 PM   #3
Daedalus704
Thanks Sharingan, I attempted to view a few of the threads on the other site and they are full of old broken links without pictures. This helps quite a bit.
Old 05-26-2012, 09:14 AM   #4
Check out either one of my build threads in the Rotary build up section
Old 05-27-2012, 07:07 PM   #5
Daedalus704
Will do, I've seen pictures here and there of your setup and the build quality is amazing sir.
Old 10-25-2012, 09:59 AM   #6
Raksj04
I have Ultra power in me.
Raksj04's Avatar
I read in one of your build threads you were thinking about using a 24x13 intercooler. I am not sure which one. I found this guy on ebay.
http://www.ebay.com/itm/CXRacing-FMI...#ht_4070wt_772
Is it a good to have the inlet and outlet be 90 degrees on the tanks, or is it better to have them to be on the side like a typical FMIC?
Old 10-25-2012, 01:01 PM   #7
EJayCe996
PPP-P-P-P-POWER!
EJayCe996's Avatar
Originally Posted by Raksj04 View Post
Let's just say two turbo Civics here, that I know personally, have separated the welds on those crappy intercoolers.... stay away.
2. Say you love dubstep
3. ?????
4. PROFIT!
Axiomatic: Total cacology.
