Old 05-14-2012, 07:26 PM   #1
fc nut
member
12a question
my sons se had a carbed 12a in it.I'm planning on using my se housings and rotors when i build his engine. i've looked at the 12a's oil cooler and was wandering, do I need to use the beehive or can I use an s4 cooler instead?
Old 05-14-2012, 08:08 PM   #2
Rich@SR
SR Race Engineering
Rich@SR is on a distinguished road
Swap it.
SR Race Engineering... Home of the "SR Nikki"
My 1st Gen SCCA Rebuild Thread
1985 Rx-7 (SCCA Racecar)
2004 Lexus IS300 (Daily)
2004 VW GTI (Wife's Daily/Toy)
Rich@SR is offline   Reply With Quote
Old 05-14-2012, 08:13 PM   #3
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
The 12A in my 79 used an oil cooler almost identical to the one in an FC. I don't know about internals or the fittings, but I don't see why not. I still have the oil cooler and front cover from the 12A, if the FC one won't work. Anyone else?
Old 05-15-2012, 07:03 AM   #4
t_g_farrell
Waffles - hmmm good
t_g_farrell's Avatar
Don't use the beehive for a 13B build. You want a front mount of some kind.
Old 05-16-2012, 06:57 AM   #5
IH8DSM
IH8DSM's Avatar
The 2nd gen oil cooler works the hard line for the back iron has to be straightened a little to fit then you will have to figure out a way to mount it
Old 05-18-2012, 08:03 PM   #6
diabolical1
I have radioactive semen
as long as you can figure a way to mount it, use the S4 cooler.
Old 05-18-2012, 10:57 PM   #7
NYCGPS
NYCGPS is on a distinguished road
Mazda did so well at most parts ... but that beehive is such a joke
swap it.
NYCGPS is offline   Reply With Quote
Old 05-26-2012, 09:27 PM   #8
fc nut
member
recently my se's oil cooler was cracked and i was gonna use an s4. i ended up getting it welded,so i was gonna use it in my sons car. his engine is gonna have se housings and 12a irons,that's why i was gonna see if it would work.
Old 08-13-2012, 03:56 PM   #9
dr.occa
dr.occa is on a distinguished road
I think my question is related:
I just recently replaced my sp 12A (lost compression) with a stock 12A. It was running the "bee hive" cooler so I pulled it already and am running a front mount. Can the hard coolant line that's still back there be unscrewed and that port plugged or ...? I didn't want to attempt to remove it yet and potentially shoot myself in the foot and introduce a new problem that didn't exist. Right now I've capped both openings but they're still leaking a bit.
Here's a picture of what I'm talking about with the orange arrow pointing out the hardline I'm referring to. (it's not my engine by the way):
dr.occa is offline   Reply With Quote
Old 09-15-2012, 09:55 PM   #10
rxtasy3
rotary madness
rxtasy3's Avatar
rxtasy3 is on a distinguished road
use an original SE cooler if u can get one, otherwise as mentioned, u can fab a mount for the s4 cooler.
rxtasy3 is offline   Reply With Quote
Old 09-16-2012, 09:40 PM   #11
IH8DSM
IH8DSM's Avatar
Just cap one of the ports with a cap they sell some in the help section of auto zone that are just for blocking coolant. You could always bend it and weld it shut.
Old 09-17-2012, 03:28 PM   #12
fc nut
member
i ditched that idea. i'm gonna use my se engine in my son's car,with a sidedraft setup. i'm gonna use the s4 cooler on his car.
Old 09-18-2012, 11:51 AM   #13
rxtasy3
rotary madness
rxtasy3's Avatar
i think those r just pressed into the housing. last one i did i just cut it off just behind where it T's off towards the firewall so there's just the single piece sticking out.
Old 10-31-2012, 06:41 PM   #14
fc nut
member
thanks for the input,however i've decided to use my se engine in my son's car.
