Old 05-08-2012, 07:57 AM   #1
frostycrowd
frostycrowd is on a distinguished road
fs high power drivetrain partout Nashville, Tn
Tennessee
Contact: By PM
I am parting out my 400hp turbo rx7. I will only be parting out the power /drivetrain and then selling the complete roller seperate. Most of the parts are lightly used as it was a second car and garage kept. Since this is a local forum saying no shipping, but will make considerations.
Paypal or cash in person excepted, I will take pictures as requested.
Engine: -s5 6 port 9.7 rotors, stock port - Compression is okay, engine doesn't smoke or burn anything. 500 Shortblock (pickup only)
-Corksport 80mm full exhaust with added magnaflow presilencer (has vband connector for downpipe) - 250 (pickup only)
-Racing beat oil cooler lines - 150 shipped
-Oil cooler - $50 shipped
-FD Alternator with Dual pulley - Belts included - $120 shipped
-Power steering pump - $70 shipped
-Red Top battery - $50 pick up only
-Yellow Top Battery - $50 pick up only
-1 Stock engine mount - $25 shipped
-Aluminum engine mount set - $30 shipped
-Banzai racing Oil filter pedestal -$25 shipped
-Corksport FRP radiator panel - $50 shipped
-God Speed Aluminum Radiator with Pontiac 2000 fan and lightly used replacement fan motor- $120(pickup only)
-Greddy "style" Intercooler setup - Complete with piping/couplers/tbolts/Throttle body elbow/intercooler - $300 (pickup only)
-6 Port intake turbo manifold (ported to match 6 port,works awesome) - $120 shipped
-Leading and trailing coils - 50 each shipped
Fuel Setup (Will separate injectors and line/rail setup only) -Parallel fuel setup - $350 s4 rails with adapters Aeromotive FPR adjustable Anodized Push Lok fittings all -6AN E85 and Petrol compatible
-2 RC1200 -120 shipped -
-2 1600cc injectors Bosch - 120 shipped
-17x8 Mustang wheels with Sumitomo Tires HRZ with 80% tread, 225mm front/255 mm rear tires-$300 pickup only
-Turbo Transmission, slight grind in 5th, but otherwise perfect - $300 pickup only
-Turbo driveshaft - $100 pickup only
-Mazdatrix Shifter with s5 shift knob - needs new bushing $100 -
ACT 4 puck sprung clutch/resurfaced ACT Stage 1 PP less than 1k miles on both, just replaced 2 months ago holds 400+ whp perfect -200 shipped
-Almost new Clutch Slave Cylinder -Beck Arnley - $20 shipped
-S5 Counterweight - $100
-Racing Beat Steel lightweight flywheel (less than 1k miles on resurface) - $220 shipped
Misc parts laying around:
2 Front KYB GR-2 Practically new (<500 miles)
- $120 shipped 3 Black door jam covers -- $15 shipped each
1 E-shaft - $70 shipped
S4 Front cover - $45 shipped (will tap for oil return for additional $25)
Exhaust Manifold to Block Gasket New - $30 shipped
4 Stock NA Injectors (red top) - $100 shipped
Universal Turbo Parts T4 weld flange - $20
frostycrowd is offline   Reply With Quote
Old 05-08-2012, 08:03 AM   #2
Ugh, so tempting. Too bad I'm poor.
Old 05-08-2012, 09:38 AM   #3
infernosg
IT'S ALIVE!
infernosg's Avatar
PM sent.
Old 05-11-2012, 07:33 PM   #4
Scratch that...
