Old 05-07-2012, 07:10 AM   #1
MacGyver
MacGyver is on a distinguished road
Help me choose apex seals and bearings
Hi guys. I'm looking to build a new engine for higher power output with a goal of 400HP on pump gas. This will be a daily driven engine, it may see an autocross one day but not often. The parts I need help with are
Apex Seals:
I've looked at 2 piece Mazda, Goopy and ALS. The Mazda have proven wear characteristics. The Goopy and ALS are regarded as great for high power applications and resistance to detonation events. Does anyone have any feedback on Goopy or ALS seal housing wear characteristics?
Stationary and Rotor bearings:
The engine I'm rebuilding has excellent condition stock bearings but I'm unsure how they will hold up in the long run at elevated power levels. Either way I will be using a Racing Beat high pressure regulator and machining a groove for an o-ring between the pump body and front iron. I'll be keeping the stock ball and spring eshaft jet as well. Additionally I (need help with) was thinking RX-8 gears/bearings and Mazdatrix competition rotor bearings along with reaming the oil passages to 3/8". Plan is to keep the redline the same. Thoughts on whether is a worthwhile mod or waste of money?
Appreciate an feedback you guys can give.
MacGyver is offline   Reply With Quote
Old 05-07-2012, 04:21 PM   #2
Sharingan 19
Sounds like a good list with the except the reaming of the passages to 3/8", not to say it will be detrimental, just haven't heard that mentioned in any of the oil mod conversations.
I'm running the Goopy seals with 9.4 rotors personally, my plan is to run around 300whp daily (low boost) and 350whp (highboost) for ....fun stuff after the engine is broken in. No the only internal mods I've done is the modify the oil pressure regulator for 80psi.
Old 05-09-2012, 07:02 AM   #3
NYCGPS
NYCGPS is on a distinguished road
I'm not sure about Groopy and ALS but Mazda seems fine for your Applications.
No Apex seal can survive too much ping, Groopy might wrap instead of breaking like Mazda, but the result is the same --- you lose compression and you need a rebuild.
but if your tuning is safe you don't have to worry too much about that in the first place, all you really need to focus on is the tuning.
You can use 13B-MSP Eshaft and Bearings, they're better and cheaper. no modification is necessary. As for Rotor bearings, you don't need the compeition one unless you are going above 8-9K rpm all the time, stock actually works quite well
for oil pressure, you can just use FD rear and add 2 1/8" shims to the front, then you are set, and much cheaper
NYCGPS is offline   Reply With Quote
Old 05-09-2012, 10:47 AM   #4
infernosg
IT'S ALIVE!
infernosg's Avatar
Good info on the oil pressure regulator - should be cheaper than buying the "upgraded" unit from Racing Beat, etc.
A note on the RX-8 stationary gears: some modification is required for the rear gear to ensure the oil passage is open and you'll need to use hylomar/silicone to seal the rear gear to the housing as there is no o-ring groove.
Old 05-09-2012, 11:29 AM   #5
If there is ever a chance that the bearing is questionable, just buy the RX8 stuff. Cheaper and better than stock replacements.
Just find an FD one
Where did you get that idea?
Ditch that, get a plug.
Just go ahead and get the 8 bearings/stat gears if there is any question.
I wouldn't w/the stock pump and the stockish system you have planned.
I wouldn't use them for anything other than stock turbo and 250ish HP
BULLSHIT. The seals I run survived a 16.9:1 @ 15psi detonation event... basically cruising @ high rpms, high vacuum and punched it. Boost when from 15" to 15 lbs in a split second and the car detonated so hard it nearly knocked teeth out. Pulled over, pulled a datalog, found the problem, fixed the problem, drove another 1000 miles before doing a compression test.... which showed 114all around
Not to mention... I would much rather have a seal warp and loose compression than break and wipe out a rotor, a housing, possibly a plate and possibly a turbo.... so no, the results are not the same
Things go wrong, and they go wrong faster than you can react. I wouldn't use mazda seals for a hi-hp engine even though plenty of people do.
This is accurate and what I run in my engine
I wouldn't add the shims. I did in mine and ended up taking them out and my oil pressure is still 135-140 at cold start, and 100psi cruising down the highway. It's just too much.
Indeed
Just make sure that it's all lined up when you test fit the gear/bearing assembly. I use a little grey permatex or "right Stuff" in the corner and that's all you really need.
-Brian @ S1
Old 05-09-2012, 12:08 PM   #6
Nismo
400WHP or bust
Nismo's Avatar
I think I paid 250 for front and rear stat gears.
Just find an FD one
I paid $35 for the stock fd, better than the $80 rb wants.
Do you machine the pump housing or the iron? I am thinking about doing this for the RE
What are you using?
Old 05-09-2012, 12:25 PM   #7
infernosg
IT'S ALIVE!
infernosg's Avatar
Forgive my ignorance but what benefit does this provide?
I'm also curious.
I guess I'm not up to speed on my oil system modifications...
Old 05-09-2012, 05:47 PM   #8
Sounds right for retail
And more base pressure, and you don't have to pull your pan off to adjust it
Pump housing. Pressure is insane. I constantly blow out the o-ring in the front cover and it ends up in the filter. Pressure is still more than adequate.
What are you using?
RX7 specialties
Reduced the chance of a future failure, doesn't allow oil to bypass
Old 05-09-2012, 05:47 PM   #9
Where ya been Kevin? Still not done w/that RE yet? Damn man
Old 05-09-2012, 07:06 PM   #10
NYCGPS
I
assume everything is fine, mazda seals will hold higher compression.
you were lucky thats all.
a warp seal might kill whatever you said as well, Mazda choose to heat treated their Apex tips for a reason.
each to their own, see above.
I agreed, but
again, each to their own. there are people who use it and they're ok with it. so can't really say who is right/wrong, just a preference.
I run Ceramics in mine. choose because it's easy on housing, and they last almost forever. sure they're harder and if they break, 99% will kill everything, but I am willing to take that risk.
The front is really just there to prevent the oil system self-destruct, most of the time it will be bypass at the rear.
I fit it without any issue, you can tell if by eye. and I just put some silicone and it works fine. Some people even use Hylomar, and they're fine. in the other words, use whatever works.
Old 05-09-2012, 07:13 PM   #11
NYCGPS
same idea as the front pulley bolt plug, there is a chance that it will fail, when it does, it always get stuck either open or closed position.
either one is bad for you.
mind u they are loctite from factory, so if u wanna remove it and install a plug, u might want to hit that spot with a propane torch for 30 seconds first, then unscrew it fast.
Old 05-09-2012, 09:01 PM   #12
MacGyver
The examples I've seen were on the pump housing. It is a variation of the notebook paper gasket but should not change the stack-up clearance.
Was yours at this pressure level even with the stock FD regulator?
Old 05-09-2012, 09:05 PM   #13
Nismo
400WHP or bust
Nismo's Avatar
Oh been busy making a baby, little girl 7 weeks old today, should have the engine built in July, should be able to start break in sometime around October.
Old 05-10-2012, 08:43 AM   #14
No. I wasn't. That's what those seals are designed for. Any other seal I'm confident would've broken. Leaving me with an 800 mile tow home, and a worthess set of rotors and housings.
I run those seals for a erason
A warp seal might kill whatever you said as well, Mazda choose to heat treated their Apex tips for a reason.
No. A warped seal will just loose compresion unless you run it for a very long time. THen it will wear the housings in a bad way
I am not. But then again I am always trying new things
Yes
Wow... congrats man.
Old 05-10-2012, 10:56 AM   #15
infernosg
IT'S ALIVE!
infernosg's Avatar
Ah, got it. So are you guys plugging this are replacing it with a fixed jet? I would think eliminating it altogether would be bad, no?
