Old 05-02-2012, 03:54 PM   #1
sen2two
KTEC
sen2two's Avatar
Compressor blade RPM = ?psi
I'm trying to choose a compressor blade and housing for my supercharger project. I am making my own supercharger from the front half of a turbo. I'm trying to get my gearing down to get 10psi at my desired RPM.
I cannot find any formulas on how much pressure a turbo will create at given turbine revolutions. Yes, i know there are many factors in this... But if someone can point me in the right direction, that would be great.
what I have:
What I had:
Old 05-02-2012, 04:32 PM   #2
RICE RACING
Don Mega
RICE RACING's Avatar
Its pretty easy, I am one of the FEW people who actually measure this in my own car
There is a direct relationship to compressor speed and psi delivered, you will find this info on a compressor map of the (half turbo) you are deciding to run. what speed you spin the compressor at will directly relate to the boost you will get But you need to find a compressor map of the unit you are wanting to convert.
If you look at my threads featuring VBOX logs of my car you will see printed in the report tables compressor speed for various boost levels
www.riceracing.com.au
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
