Old 05-02-2012, 12:37 PM   #1
Force13b
cxxxx|::::::::::::>
Force13b's Avatar
Fuel pump assembly and fuel bulkhead
Buy both for 130$!
Universal Bulkhead connector fromRaceTronix they go for 49 yours for 40$ shipped to your door.
Fuel pump assembly with Napa fuel pump has burn wire connector see below 100$obo
The story...I've been helping a friend with his car for a little over a year now. After a lot of other things had been fixed we found the fuel pump had burnt out the wires. I was just going to use the bulkhead connector and rewire the pump, he decided to just buy a new fuel pump housing from Ray Crow. Now i have parts that need to go.
Old 05-02-2012, 01:56 PM   #2
Trout2
Trout2 is on a distinguished road
Nice find. Any pics with it installed.
I got a 4-wire Fuel Safe bulk head connector last fall for $110 for both pieces but they recently raised the price another $40.
Jack
Trout2 is offline   Reply With Quote
Old 05-02-2012, 02:25 PM   #3
infernosg
IT'S ALIVE!
infernosg's Avatar
I was actually staring at this piece on my FC last night. How does one go about replacing the connector? What size wire? I don't suppose this is a drop-in piece?
Old 05-02-2012, 03:00 PM   #4
Force13b
cxxxx|::::::::::::>
Force13b's Avatar
I never installed it. I bought it for a friend to do the setup and he went another direction. You would need to drill a hole somewhere to get this to work it's not plug and play. Here's a link to the part
http://www.racetronix.biz/itemdesc.a...WS-001&eq=&Tp=
Each color-coded 14 gauge wire can handle 14 amps continuous and 20 amps intermittent duty.
Old 05-02-2012, 11:25 PM   #5
Trout2
The one I used fit the hole where the OEM bulk connector was. Had to cut off and grind down the lip for that hole. Then the hatch cover had to be trimmed to clear the connector.
Old 05-03-2012, 08:50 AM   #6
infernosg
IT'S ALIVE!
infernosg's Avatar
I may still be able to use this by dedicating all four wires to power/ground. PM on its way.
Old 05-07-2012, 12:28 PM   #7
Force13b
cxxxx|::::::::::::>
Force13b's Avatar
Sold and shipped to ^
