Old 04-18-2012, 12:28 AM   #1
magpiemini
magpiemini's Avatar
magpiemini is on a distinguished road
Question 1984 GSL-SE Caliper Questions
First, both the front and rear rotors are single piston, one side, YUCK, even the old English cars used at least two pistons. Any suggestions for better calipers?
Second, I was able to open up the front caliper wide enough for new pads but the rear caliper was a problem. I could not press the piston back, they do work so I know they are not stuck. I could not use new pads, had to put the old pads back in for now.
Is there a trick or special tool for those rear calipers?
1984 RX7 GSL-SE
Building for the 24 Hours Of Lemons
magpiemini is offline   Reply With Quote
Old 04-18-2012, 04:01 AM   #2
2gslse
The rear calipers have to be turned back in there is a couple small notches on the piston that a tool fits into and turned clockwise ( the tool is usually like a small block or sometimes a pair of needle nose pliers will work)
2006 VW TDI commuter
Old 04-18-2012, 10:38 AM   #3
magpiemini
magpiemini's Avatar
DOH! Thanks, I was trying to press them back in.
1984 RX7 GSL-SE
Old 04-24-2012, 03:40 PM   #4
Garfinkles Motor Works
The parking brake was not your friend.Try to find a repair book it may save you some time and money .
Old 04-25-2012, 12:14 PM   #5
^ To what he said, you can download a copy of the factory shop manual here: http://www.wright-here.net/cars/rx7/manuals.html
The 1984 & 1985 editions will have your GSL-SE model covered.
Old 05-03-2012, 03:13 PM   #6
magpiemini
magpiemini's Avatar
I have two now, I just did not read them first. You can lead a dumb-arse to water but he may run away so he don't get wet.
1984 RX7 GSL-SE
