View Poll Results: What oiling setup to use for racing
Leave it stock and run the right engine oil 0 0%
Leave it stock and add some pre-mix 8 53.33%
Disable the metering pump and pre-mix 6 40.00%
Other - I have posted a better idea 1 6.67%
Voters: 15. You may not vote on this poll
Old 04-09-2012, 11:50 AM   #1
magpiemini
magpiemini's Avatar
magpiemini is on a distinguished road
Pre-Mix Oil What - HELP?
I am new to rotary engines and had no idea they had an oil metering pump or you could pre-mix or both. I just read about it in the sticky post.
Where can I read up on this?
Where is this oil metering pump?
What is the recommended setup for racing?
What type of oil should I use?
1984 RX7 GSL-SE
Building for the 24 Hours Of Lemons
magpiemini is offline   Reply With Quote
