Old 04-01-2012, 10:59 AM   #1
krivman65
krivman65 is on a distinguished road
going from manual to automatic (crazy I know)
Ok, so I have an engine that had a 5spd behind it and am trying to bolt up an automatic. It appears that the end of the eccentric shaft is different!!!! Believe you me, I would rather have a manual, but I am not cutting up the tunnel to fit this 5spd in there.(it's a '73 rx2) Has anybody heard of an adapter to go this direction? Or do I just have to bite the bullet and rebuild my original motor?
krivman65 is offline   Reply With Quote
Old 04-01-2012, 11:58 AM   #2
2gslse
I don't think the eccentric is any different from 1 trans type to another could you post up some pics of what you are seeing?
2006 VW TDI commuter
Old 04-04-2012, 05:28 AM   #3
It might looks different cause the input shaft on the automatic transmission doesn't require a pilot bearing like a manual transmission requires.
Remove the pilot bearing (and seal), and it should fit.
Old 04-17-2012, 02:42 PM   #4
Drama
Drama's Avatar
Drama is on a distinguished road
It will fit for sure, just do as RETed said, I done all generation from auto to manual and vise versa.
10th A.E. with 94 Twin Turbo FD Engine, With a precision turbo SC 60. Tokico Blues, B & G springs, Racing beat sway bars, Fender braces, F & R strut braces, Stainless brake hose`s, Toe eliminator busings, Carbon/Kelvar GT300 hood, Depo Gauges,Catz fogs,Sparco 383 steering wheel, 3rd gen shifter knob.
Falken Anzenis Rt 615`s
Front wheels 17X8+35 245/40
Rear wheels 17X9+44 with 5mm spacer 275/40
Drama is offline   Reply With Quote
