Old 03-07-2012, 10:40 AM   #1
Roen
Evil Club Mod
Roen's Avatar
Mazdatrix Titanium Rotors
So we have another player in the lightweight rotor game. If some of you remember, East Coast Racing came out with Billet rotors a little while ago. Now Mazdatrix has announced its Titanium rotors that they hope to get under 6 lbs.
Thoughts?
Ex-King of the Loop / Captain Guardrail / Master Crab Rapist / Evil Crop Dusting Mod
Old 03-07-2012, 11:31 AM   #2
t_g_farrell
Waffles - hmmm good
t_g_farrell's Avatar
Where did you see/hear this? I can't find any mention on their web site.
Old 03-07-2012, 12:20 PM   #3
Roen
Evil Club Mod
Roen's Avatar
http://www.rx8club.com/showthread.php?t=230169
Old 03-07-2012, 02:25 PM   #4
Titanium is not a good material if there is any chance of metal-to-metal contact.
Titanium galls like a mofo.
Add to the fact now you've got another different metal with differing (heat) expansion rate, and you've got one messy engine unless you calculate all the clearances correctly.
I bet it's almost necessary to run those under apex seal oil jets that Hurley Engineering was touting a few years back just to keep the apex seals from seizing in their slots...
Old 03-07-2012, 03:19 PM   #5
RICE RACING
Don Mega
RICE RACING's Avatar
Yep what he said,
I made my own Ti seals in 1994, they were fucked
There is a reason it is used as a rubbing block on the bottom of F1 cars LOL. MASSIVE SPARKS.
If you ever tried to grind Ti on abrasive belts, good luck you will see what we are both saying to cut it is fine (machines great!) but "rubbing" its a disaster as natural as a homo having sex.
The Ti will need some sort of coating or insert on all the seal slots to work.
www.riceracing.com.au
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 03-07-2012, 05:03 PM   #6
rxspeed7
The fan hit the shit!
rxspeed7's Avatar
not worth a bajillion dollars to save a couple pounds nor will mztrix make it usefull and functional!! All they will accomplish is making a cool sparkler!!
Many ways you can get BDC'd
Old 03-08-2012, 09:57 AM   #7
sa22c
sa22c is on a distinguished road
My take is that they might be of interest in sponsored rotary drag racing.
I'm yet to see evidence of any one in the world undertaking a controlled scientific test to see what the real limit of the factory rotor engine is when its correctly running. I have no doubt 1MW could be generated for a minutes at a time using just about any factory twin rotor if all the conditions were controlled.
Plant to supply the boost on a dial in a test cell
Inductrial sized Coolant and Oil Coolers
Controlled test fuel
Correct mixture and ignition calibration
sa22c is offline   Reply With Quote
Old 03-08-2012, 10:13 AM   #8
I saw this on facebook. Didn't even think about how it would work with the other metals as far as expansion and all that. Not that I was going to get them anyway haha.
Old 03-08-2012, 07:23 PM   #9
EJayCe996
PPP-P-P-P-POWER!
EJayCe996's Avatar
There you go
http://www.ewp.rpi.edu/hartford/~les...unterfaces.pdf
2. Say you love dubstep
3. ?????
4. PROFIT!
Axiomatic: Total cacology.
Old 03-09-2012, 10:57 AM   #10
Raksj04
I have Ultra power in me.
Raksj04's Avatar
Originally Posted by EJayCe996 View Post
Tech paper FTW!
Old 03-09-2012, 01:53 PM   #11
Why not just coat the titanium rotors with ceramics?
Old 03-09-2012, 02:31 PM   #12
EJayCe996
PPP-P-P-P-POWER!
EJayCe996's Avatar
Some sort of dry film coating is basically what most of the documents related to titanium from the site in my last post suggests. You have to stop the titanium from transferring a layer onto the other metal it has friction with.
3. ?????
4. PROFIT!
Old 03-13-2012, 11:07 AM   #13
reddozen
Gold Wheels FTW
reddozen's Avatar
The rotor shouldn't be making contact with anything other than the misc seals (apex, side, corner, etc). If it is making contact with the epitrochoid, then you have other very serious problems... I do think they will be too light for street use. I'm curious to see what the dyno says and what the RPM response rate looks like both on accel and decel.
My Cars:
1974 RX4 Coupe
1991 FC3S RX7 - Sold
Old 03-13-2012, 12:37 PM   #14
I wonder how light they'll actually seem in regards to drivability. People go from a stock flywheel (17lbs?) to one under 10 and are fine with it. I'm sure due to differences in inertia, center of mass, and other stuff I don't really understand it's not a direct comparison, but the question remains the same: How much will shaving 5 lbs off the engine's rotating mass affect drivability?
Old 03-13-2012, 10:15 PM   #15
FC Zach
FC Zach's Avatar
I believe it's more of a concern with the rotor touching the irons, not the epitrochoid. If all is clearanced, shouldn't be a problem but if not that is when galling starts.
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
