Old 03-04-2012, 03:45 PM   #1
need RX7
Clean S4 Nutswinger
need RX7's Avatar
Water pump hardware specs
I've managed to lose all of the hardware responsible for holding the water pump and water pump housing onto the engine. I need to replaces all of the nuts+lock washers, the 2 short bolts and the long bolt. Does anyone have length and thread specs for the bolts, and thread info for the nuts?
Old 03-04-2012, 05:07 PM   #2
need RX7
Clean S4 Nutswinger
need RX7's Avatar
I found out that the thread of the studs is M8 x 1.25, so I assume the threading of the bolts are the same.. right? If that's correct, the length of the long bolt is my biggest concern.
