Old 03-02-2012, 02:49 PM   #1
need RX7
Clean S4 Nutswinger
need RX7's Avatar
rhythmic squeak from rear end
Just recently, my car has developed a new sound. It has the same rhythmic pattern as a warped rotor (increases with speed, etc), but not the typical scraping sound. It's more of a rubbery squeak. I jacked up the rear end and turned each wheel by hand, they didn't have any more resistance than usual or make any noise. I felt around and didn't find anything rubbing the tires. I forgot to check to see if anything was rubbing the driveshaft.
I had someone tell me it was a wheel bearing, but I'm not too sure. Wouldn't a wheel bearing be a constant hum?
Old 03-02-2012, 03:14 PM   #2
Raksj04
I have Ultra power in me.
Raksj04's Avatar
Does it change if you accel or deccl?
Old 03-02-2012, 04:54 PM   #3
need RX7
Clean S4 Nutswinger
need RX7's Avatar
The tempo increases depending on speed, but the sound itself doesn't change.
Old 03-08-2012, 03:10 PM   #4
need RX7
Clean S4 Nutswinger
need RX7's Avatar
So I jacked up the rear-end today and discovered that the rear driver side wheel does indeed have some wobble. Crap.
Old 03-08-2012, 04:00 PM   #5
Have fun!
