Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > Rotary Diagnostics Systems
Rotary Diagnostics Systems Our Rotary-engine Compression Testers combine off-the-shelf hardware and software to create a reliable system that can be used to obtain accurate engine compression measurements from a rotary engine. www.rotarydiagnostics.com P.O. Box 524 Mont Alto. PA 17222 (717) 352-7096
Old 02-28-2012, 12:13 PM   #1
ZGN
Administrator
ZGN's Avatar
Rotary-engine Compression Tester Systems www.rotarydiagnostics.com
I would like to thank Larry at Rotary Diagnostics Systems for his support of RCC! His contribution will go towards the continued promotion of this forum.
Check out his website www.RotaryDiagnostics.com and feel free to post questions for more information on his Rotary-engine Compression Tester Systems.
Thank you!
Figure 1. Model ReCT-TRT, Two-rotor Compression Tester System.
The Processing Unit includes an enclosure containing the analog-to-digital converter, DIN data sockets for 2 Acquisition Units, plus the power and data connections. Power and USB cables, as well as the programs CD are a part of the Processing Unit. The Processing Unit receives analog signals from the Acquisition Units during a compression test and converts them to a digital data stream for transmission to the computer for recording and later display and analysis. The Acquisition Units consist of precision pressure transducers with attached 30" cable and DIN connector, a spark plug hole adapter with swivel air plug, and a quick coupler fitting for easy connection of the components.
P.O. Box 524
Mont Alto. PA 17222
(717)352-7096
Kevin
Old 02-28-2012, 12:32 PM   #2
rxspeed7
The fan hit the shit!
rxspeed7's Avatar
Group buy?........
Many ways you can get BDC'd
Old 02-28-2012, 01:19 PM   #3
rx71king
rx71king's Avatar
rx71king is on a distinguished road
whats the price on that bad boy...?
rx71king is offline   Reply With Quote
Old 02-28-2012, 01:22 PM   #4
rx71king
rx71king's Avatar
http://www.rotarydiagnostics.com/pricing%20combined.htm .......found it
Old 03-26-2013, 04:53 PM   #5
9krpmrx8
SARX + Boosted = Win
9krpmrx8 is on a distinguished road
Anyone have an experience using this product?
9krpmrx8 is offline   Reply With Quote
Old 03-26-2013, 10:41 PM   #6
Dannobre
I have had one for 4 years...works well....It is much more complex than the Mazda tester to use the first time..but after you have done it it is quite easy
It also gives you more data than the Mazda tester...
Old 03-27-2013, 11:00 AM   #7
Monkman33
Still Building my FD
$640 ... no thanks. And $225 for a software upgrade in sampling rate? Alrighty then Motec.
If the two rotor system was reasonably priced, I would have already purchased one.
Uh.... hi.
Old 03-27-2013, 12:13 PM   #8
RotaryDiagnostics
Compression Tester Man
RotaryDiagnostics's Avatar
You do not need the $640.00, 2-rotor system to acquire accurate compression readings on all compression faces of both rotors of a rotary engine. Our basic system allows you to test both rotors, just not simultaneously, and is priced at $355.00. Maximum sampling rate for that system is 240 samples per second which is more than adequate for determining accurate compression readings. Incidentally, the software upgrade is not required nor is it available for that system.
The other systems we offer are intended primarily for engine builders and rotary shops where a higher resolution sampling rate provides detailed analysis of the compression pulses and where the presentation format of the data to their customers may be critical. Of course, we sell those system to individuals as well.
There, now I feel better.
Larry Roberts
Rotary Diagnostic Systems
Old 03-27-2013, 01:53 PM   #9
Monkman33
I appreciate your very professional response to my post which was in poor taste. My apologies. I guess I'm just a cheapskate.
Uh.... hi.
Old 03-27-2013, 03:14 PM   #10
RotaryDiagnostics
No apology required, but thanks anyway.
Old 03-28-2013, 12:04 PM   #11
Dannobre
LOL...try and buy a Mazda one....even the $640 price looks like a steal then
Old 03-28-2013, 12:12 PM   #12
RotaryDiagnostics
Well ya know, that could be why Mazda Australia opted to adopt our basic system for 60 of their dealerships. Ya think?
Old 07-26-2013, 12:24 AM   #13
chibikougan
chibikougan's Avatar
Originally Posted by rxspeed7 View Post
Group buy?........
Second this?
Old 07-26-2013, 08:59 AM   #14
Second this?
Third this?
Old 07-26-2013, 08:44 PM   #15
Monkman33
Fourth this?
Uh.... hi.
