Old 02-16-2012, 10:35 PM   #1
7799brady
7799brady is on a distinguished road
Lsd
Hello just joined and looking for info on LSD that will fit a 79 rear axle
7799brady is offline   Reply With Quote
Old 02-22-2012, 09:12 PM   #2
burnoutking999
burnoutking999 is on a distinguished road
I thought this thread was about a new chevy engine for a minute.
burnoutking999 is offline   Reply With Quote
Old 02-24-2012, 10:39 PM   #3
Kentetsu
Kentetsu's Avatar
With the right combination of driveshafts, you can make any of the 1st gen rears fit. The only issue you will run into is with a thread change on the brake lines. I believe www.re-speed.com sells an adapter set for that purpose.
A GSL will have 4x110 spacing and disc brakes/lsd
A GSL SE will have 4x114(?) spacing and disc brakes/lsd
So, unless you want to end up with an unintended wheel change, be careful which rear you get.
