Old 02-16-2012, 12:38 AM   #1
IH8DSM
IH8DSM's Avatar
s4 na stutters when cold
Just like the title says I got a na s4 all stock that's has a random stutter issue. It really only does it when the weathers cold you'll go to hit the gas and nothing rpms don't even go up pump the gas a few times and it will start to drive normal again. does it both at idle as well as when driving when I left off the gas for a second then try to get back on it.
It idles high (1500rpms) and adjusting the top screw doesn't do anything so im swapping it with a stripped down throttle body and a different tps and hoping this will fix my issue. Just curious if there's anything else I should check or change if the new throttle body and tps doesnt fix my problem.
Its got a new fuel filter on it, fresh plugs and wires, ran chemtool throguht it twice now. The motor starts when its hot or cold no problems and was supposedly rebuilt about 30,000 miles ago.
Old 02-16-2012, 12:55 AM   #2
WankelsRevenge
WankelsRevenge's Avatar
Im sure this might be an obvious question, but do you let it get up to temp before starting off? I had an old S4 NA and it wouldnt even idle before it got warmed up.
Ryan
Summary of this thread:
Old 02-16-2012, 01:08 AM   #3
IH8DSM
IH8DSM's Avatar
It takes a second to idle when its cold outside but will idle no problems after that, I've tried letting it warm up to operating temp and it usually doesn't do it as bad, instead of hitting the gas and nothing happening its like a hiccup then realizes what's going on and goes.
Old 02-16-2012, 02:00 AM   #4
FC Zach
FC Zach's Avatar
Sounds like your on the right track as far as things to pin-point the problem (TPS and TB). Sounds like the standard operating procedure.
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 02-16-2012, 09:30 AM   #5
If you have the BAC hooked up then turning the idle screw will do nothing unless you ground the initial set coupler as the BAC is still working to keep the idle. TPS maybe, but as you say it is idling ok, wihch is a good sign for the tps. The rest of its function can be checked with a multimeter.
sounds to me like you are running a little lean.
Old 02-16-2012, 03:07 PM   #6
IH8DSM
IH8DSM's Avatar
So what are you thinking maf maybe
Old 02-17-2012, 09:05 AM   #7
I have pretty much anything S4 N/A for parts if you want to try swapping some stuff out.
