Old 02-09-2012, 01:03 PM   #1
wankel12a
wankel12a's Avatar
wankel12a is on a distinguished road
Rx8 seats installation
I have a pair of seats that I want installed in a 1st gen, any info greatly appreciated...
wankel12a is offline   Reply With Quote
Old 02-09-2012, 01:30 PM   #2
IH8DSM
IH8DSM's Avatar
good luck heard they hit the door panels or center counsel. el cantino (not spelled right) did it to his black 1st gen he might be able to help.
Old 02-09-2012, 04:51 PM   #3
They are quite wide, like Adler said. Depending on what year yours is it might be easy or hard.
Either way, custom brackets are required. If you bought leather powered seats, then you will need to wire them in as well.
Old 02-09-2012, 10:56 PM   #4
Start with a plasma cutter, spot weld cutter, 4.5" angle grinder with sanding and cut-off discs, BFH, and a few feet of .125" or .185" thick steel maybe 1.25" wide.
Cut off ALL the mounting tabs for the RX8 seats.
Build new brakets
Weld to seat rails
Paint
sit in seats
Profit!!!
Old 02-10-2012, 09:26 AM   #5
IH8DSM
IH8DSM's Avatar
And what mr ttt described is about 3 hours worth of work. Why not some good t2 seats
Old 02-10-2012, 10:02 AM   #6
Try 8. I've done a few RX8 seat installs, they all take between 6-8 hrs of work. Granted I've got a few different levels going and it takes a while to get the car itself plumb, but still. Its alot of work. Comfy fucking seats though. I'm old, I have a bad back and knees and I drove in that car fofor6 hrs straight, got out and felt great.
Old 02-10-2012, 11:08 AM   #7
+1
It takes way longer than that to do it right... especially while tack welding in the car with full carpet surrounded by wet towels...
I was really disappointed in my seats because I thought I messed up the seat height. Then I realized the drivers seat was all out of adjustment and all was well. One seat leaned just a little farther back makes a big difference!
Old 02-10-2012, 08:27 PM   #8
All very true. Plus, the way I did it in the FC was to build a whole new bracket welded to the floor....
Old 02-10-2012, 09:06 PM   #9
IH8DSM
IH8DSM's Avatar
didn't mean to put 3 not sure why haha, it took paul and charles most of a day to get one in. I was "slightly" medicated this morning to say the least so yea what little paul and tttttt said
Old 02-11-2012, 02:26 AM   #10
jhereg
jhereg is on a distinguished road
425motorsports has seat brackets. I was able to still use the rx8 sliders, and electronic adjustments. Couple washers to raise the height of the drivers side to it moved without hitting, and the passenger side sits a bit higher, but I love the seats. My wife is 5'3" so she likes the seat that way.
http://www.425motorsports.com/plante...passenger.html
jhereg is offline   Reply With Quote
