Old 01-15-2012, 12:08 PM   #1
cturbo28
cturbo28's Avatar
cturbo28 is on a distinguished road
SSM RX7 Build
Anyone interested in seeing my FD project that I have been developing over the past two SCCA autocross seasons?
General Specs:
1993 base model FD.
Engine:
Stock re-man engine with about 6K on it.
Custom Precision Turbo HP5530SP with .78 AR T3 exhaust housing twin scroll.
Custom V-mount intercooler
Greddy elbow
Custom V-mount cross flow radiator "Afco"
Custom CAI 4"
Custom HPP Delrin engine mounts
Exhaust:
Custom 3.5" downpipe
Custom short runner turbo manifold divided with twin wastegates
Custom stainless flex joint
Custom 4" exhaust from DP.
Magna Flow 4" round exhaust
Custom 4" tip adjustable angles for sound restrictions
Fuel:
Bosch 044
Custom 5 gal aluminum cell
Custom fuel fill cap mounted on passenger side
-6 AN fuel lines
KG fuel rails
FPR aeromotive import style
Custom surge tank in-tank
ID2000 injectors
Electronics:
Haltech PS2000 tuned by Ludwig lmsefi.com
Haltech EGT's via CAN hub TC2 lmsefi.com
Haltech SSR for Electric water pump
AEM exhaust manifold pressure sensor lmsefi.com
AEM boost control pot lmsefi.com
Greddy boost gauge
NGK wideband lmsefi.com
LS2 coils (soon to be AEM)
Magnacore spark plug wires
NGK racing plugs (ouch) 10.5's
Greedy racing plugs 11's lmsefi.com
Suspension:
Custom valved Koni 28's aluminum body by Pro Parts
Custom spherical bearings on all pick up points.
Tri point front sway bar
Stock rear sway bar
Custom upper control arms ( adjustable on the car!) new design in progress
Custom lower front ball joint, replaced stock with spherical.
Rx7 store toe links and rear trailing arms
Shoes:
CCW 18x11 7.5 backspace fronts with Hoosier 315/30/18's
CCW 18x12 7.5 backspace rear with Hoosier 335/30/18's
Rain set up FNO1R-C 17x10 +35 All four 275/40/17's Hoosiers
Trans and stuff:
Stock trans with short shifter
Stock re-main flywheel
ACT pressure plate
LWFW (TBD) not installed at this time
TN clutch 4 puck solid disc
Kaaz diff set at 66%
Stock PPF
Delrin diff bushings
HPP racing diff brace
Custom HPP torque v-brace
4.10, 4.77, 4,44 gear ( trying to test to see which on is best for the car.
Aero:
Custom front splitter Aluma core ( made by Tomsn16)
New Ciro racing design rear wing.
Body:
Pettit rear flares
Custom English wheel rolled front fender to tuck the 315"s
Awesome bare custom hood with cut out for IC
Racing shield aluminum seats with custom aluminum mounts
Sparco steering wheel
Misc specs:
2510 lbs without driver
Relocated ABS system
Hawker battery relocated
Dyno sheet will be posted soon
SW20 EHPS mounted behind passenger seat.
EWP Craig Davis 7/21/12 installed
This is a picture of the last SCCA race last year held at our own Nashville Super Speedway in October.
Instead of flooding the Thread will a bunch of pictures I will just ad pics that people are interested in or request.
CT
93' FD
cturbo28 is offline   Reply With Quote
Old 01-15-2012, 02:10 PM   #2
Looking good Carter!
Your car is a purposed built monster.
Old 01-15-2012, 02:55 PM   #3
calculon
Hi
calculon is on a distinguished road
I'm interested in seeing pictures of the relocated ABS project.
calculon is offline   Reply With Quote
Old 01-15-2012, 05:08 PM   #4
Custom CAI 4"
LS2 coils
Custom torque v-brace
relocated ABS system
Do you have pics of these things? LOL!! I'm REALLY interested in the dual WG turbo manifold though. I've been wanting to do the EXACT same thing and I'd like to see what's possible. Are the runners equal length? What size WG are you using?
Also very interested in the custom VMIC. How big is the core on your IC? I'm looking to remake my IC for my V-mount as well. I've been wanting to do a vent in the hood like that too.
What is the v-brace you're talking about? And what about the FPR makes it euro style, what do you mean there? Really I'd just like to see how you have all this stuff set up.
I was thinking an english wheel could be used to change the fenders, but I'd been told the metal was too flimsy. Originally I was going to try to get mine done like that too but I went a different direction.
Pretty awesome, man! I'd actually like to see pics of the whole car but I know you don't want to flood the thread. This list would be cool but if you can at least put up pics of the VMIC and turbo manifold that would be great.
Old 01-15-2012, 05:14 PM   #5
cturbo28
cturbo28's Avatar
Thanks for the interest. I will have to dig up some pictures on the ABS relocation. Here is a picture of the tank install with the ABS unit next to it. I mounted the ABS unit behind the passenger seat next to the tunnel. Also I pulled the ABS ECU from the Left rear and relocated it where the rear right speaker was located. I eliminated all the wiring from the driver side all the way around to the passenger side, the ABS ECU wiring harness basically circled the vehicle. I only had to splice about 10 wires to the unit itself. It was not as difficult as I thought it was.
I will dig up some more pictures, these are not that great for the ABS relocation. Also I used the -3AN speed flex lines with aluminum banjos from the unit all the way to each wheel.
Goals:
Weight reduction, relocate weight to the lightest corner of the car.
ABS ECU = 2.2 lbs
ABS unit = 14 lbs
relocated to right rear corner of car.
Removed 7 lbs of steel fittings, tees, brackets from the stock brake lines.
I have not had any issues with brakes, 2 seasons of racing so far. Well except for the master cylinder failing at NSS last year.
CT
93' FD
Old 01-15-2012, 06:18 PM   #6
cturbo28
cturbo28's Avatar
SpeedJunkie:
Thanks, I do have pictures of everything...Just need to find them all. I can post them slowly. I have the next two days off so I have plenty of time.
The FPR is just a compact design, nothing special. just smaller. I guess it sounds cool.
http://www.summitracing.com/parts/AEI-13105/
Pictures of the manifold build
I could not find a decent aftermarket fender to my liking so I had someone make some for me. The metal is really thin as you say but the English wheel does a nice job stretching the metal out. The only issue with this set up was cost. It really hurt the pocket.. The pictures do not do the fenders justice. They look stock. But try fitting 315's on 11" wide wheels with stock fenders.
I will make another post for the V-mount set up.
CT
93' FD
Old 01-15-2012, 06:26 PM   #7
MaczPayne
Bah!
MaczPayne's Avatar
SSM allows custom control arms? Hmmmm
Johnson
TA FC in the works!
Old 01-15-2012, 07:02 PM   #8
cturbo28
cturbo28's Avatar
Yes
Speedjunkie pics:
V-mount stuff,
HOOD, stripped of paint and cutting hole for IC vent.
Intercooler, core is 18x12x2.5, I also welded the IC pipes so I would eliminate hoses blowing off at a race.
4" CAI
AFCO dual pass radiator. This radiator is split in the center. The entry is on the passenger side and the water flows over and up to the driver side to exit. I also used the stock fans on the bottom.
CT
93' FD
Old 01-15-2012, 10:06 PM   #9
rx7 vinnie
I SEE DEAD PEOPLE
rx7 vinnie's Avatar
Carter is my hero........
03 Dodge Viper SRT-10 Vert
16 MB ML350
Old 01-16-2012, 02:44 AM   #10
josh18_2k
soooo you're not allowed to duct after the radiator, but intercooler is OK? sounds like that rule is broken.. (I'm XP btw, same ducting rules)
Old 01-16-2012, 07:56 AM   #11
HOLY fuck I just typed out a bunch of stuff and it's all gone now. FUCK!!!!
I see what you mean about that FPR. I've seen those before but I didn't know they were referred to as Euro.
That fuel cell is crazy. I can't believe it fits under the bin, and I like how it uses all the previously unused space as it angles back. Those fenders came out really nice too! Do you have fans mounted to the back of your oil coolers? That ABS relocation must have taken an amount of work I wouldn't want to do LOL. Seems like it would have taken more than you're letting on lol. I like that CAI too. I was thinking of doing something similar, just not that far forward, maybe just where the filter is beside the headlight. Oh I like that heat shield above the DP too.
I love those short runners. SUPER short. Do you have any problems with oil drainage from the turbo to the pan? Do you still use the front oil drain hole? I have two EGT bungs I'd like to weld in too, looks like there might be room on top of the runners. Not sure if it would be easy to get in there around the turbo to install them though. Did you get that exhaust flange from Racing Beat? Did you use 304 or 321 for that runner? I can't believe you were able to route the WG dump back into the exhaust too, that's awesome. I have so much trouble putting mine back together with just one WG as it is. I'd love to do this though and cut down on noise. And I love the 4" DP, but I don't want to get rid of the resonated MP and GReddy Ti, so I'm not sure a 4" DP alone would be very beneficial. Are you running water/coolant to those wastegates? If so, where did you route them from and back to? I bought the same ones and I'm trying to figure out where to source the water from.
What brand IC core is that? Did you do the same size piping on both ends of the IC? I've been looking at Bell IC cores and I'm trying to figure out what size to get so it's not too big and not too small. My main goal is response. Have you ever used a different IC and different exhaust manifold with that turbo? If so, is there a noticeable difference in response between this setup and that one?
Thanks for sharing!
Old 01-16-2012, 09:47 AM   #12
Brent
Sua Sponte
Brent's Avatar
Looks awesome as always Carter!
Old 01-16-2012, 10:56 AM   #13
cturbo28
cturbo28's Avatar
Good point but I do not have any "ducts" in or on my car. Also the cardboard was just used as a template (only good picture I had). The final design is 4 inches away from the IC. This means that the hood has a "vent". Rules say hoods are free. Also my hood is vented less than most after market bling bling ones. Thanks for the concern.
Answers for speedjunkie:
Do you have fans mounted to the back of your oil coolers? Yes one 10" fan.
Do you have any problems with oil drainage from the turbo to the pan? Not at all, and I am using the front drain also. I believe I use -10AN on that one.
Yes
321 SS from Burns stainless. everything is 321 up to the 4". The 4" exhaust is 409 and it starts at about the rear of the transmission.
Are you running water/coolant to those wastegates? Not at this time. This is one of my next season projects because I have over heated the rear diaphragm twice at a race limiting my boost to 15psi which = slow. Also I might have to relocate the WG since it is close to the DP.
It was not easy, also in SSM we cannot run open WG's. All exhaust must exit rearward of the rear axles.
What brand IC core is that? Did you do the same size piping on both ends of the IC? the IC is a cheap ebay core, I was experimenting and did not want to spend big bucks on a IC if it did not work. Also it is 2.5" in and out. I think I have pretty good response if not too much sometimes. Bell IC cores would be my first choice too.
Have you ever used a different IC and different exhaust manifold with that turbo? If so, is there a noticeable difference in response between this setup and that one? I have not had anything different, I plan to change something this year if I have time. I went from a stock set up to this so with that it was a BIG difference.
CT
93' FD
Old 01-16-2012, 11:42 AM   #14
Rotary Afterfire
Where are the girls?
Rotary Afterfire's Avatar
Rotary Afterfire is on a distinguished road
Im loving that exhaust manifold...to the point Ive decided to make it...I needed one anyway.
BMW 330i daily
1993 FD3S
Rotary Afterfire is offline   Reply With Quote
Old 01-16-2012, 11:47 AM   #15
cturbo28
cturbo28's Avatar
Thanks Brent. BTW Brent will be testing my new design on my upper A-arms. They are pretty bad a$$ IMO. I have been running mine for two seasons but he will testing then on the track, mine have only seen AutoX's.
And the list goes on with pictures.
The first pic is the custom surge/anti slosh tank installed in the 5 gallon cell. It basically fills itself with the return. If the tank fills to the top I have a drain hole on the top of the tank to drain excess out. The little red thing on the right is the one way valve which is mounted on the opposite side of the picture. I do not have a LP pump feeding this but I can run very low on fuel and still not starve. I have estimated by weight that I have been down to 2 gallons with no issues. Also I have mounted the stock low gas warning light inside the surge tank. If the light comes on that means the surge tank is below half way ( it has never came on). Oh! did I mention that my stock sending unit is still operational.
The second pic is a picture of the fuel pump with filters. I used chevy truck stock filters. If they fail at a race I will not be stuck since every Advance or Autozone has these in stock. Also (Speedjunkie) you can see the custom V-brace in this picture. it attaches the diff cradle to the car and helps with PPF flex (maybe).
The best thing about this fuel pump set up is that the stock plastic cover fits over it and hides everything. I removed it for the picture but I run the plastic to protect the pump and filters from rocks and such.
CT
93' FD
