Old 01-08-2012, 01:15 AM   #1
mattallac
mattallac's Avatar
4x110 brake rotor brands?
Hi ,I am looking for some help to find who makes performance brake rotors for 1979-1983 4x110 .I have found ssbc and powerslot ,wondering if anymore knows of any other companies make front rotors(slotted ,drilled ) for street use that are of good quality?
Old 01-09-2012, 04:33 PM   #2
eprx7
eprx7 is on a distinguished road
If you are looking to get better brake performance than you should stay with the stock brake rotors and just up grade your pads. I have been using Hawk HPplus pads for my sa for about 8 years they aren't going to wear out you rotors fast and they have great stoping power. The bad side of them is that they do create a lot of brake dust. They are good for street/ autox use as well as light track day use.
I had to upgrade to a better pad for track use as I got faster I am now using the Hawk blue and black pads which give better stoping power but are not for street use because they need to be warmed up before they work well.
You can contact andrew-racing.com and he can guide you in the right direction, he handles pads ,rotors ,and brake fluid.
1979 SA F Prepared solo/ Track day car 12a w/Weber carb,RB header and exhaust,
Ground Control coilovers, camber/caster plates
GforceEng.panhard rod w/ tri-link,Panasports wheels w/Hoosier slicks.
eprx7 is offline   Reply With Quote
Old 01-09-2012, 04:58 PM   #3
mazpower
Rawr Bearclaw
mazpower's Avatar
mazpower will become famous soon enough
I run the Powerslot rotors on my '82 with Hawk HP Plus pads for street use and the occasional track day. I was running a 6-port half-bridgeport 13B with 9.7:1 rotors, now I'm running a NA REW, and this pad/rotor combo works well for the street other than the dust.
Illicit Performance
Rotary building, porting, tuning, chassis dyno services
www.illicitperformance.com
mazpower is offline   Reply With Quote
Old 01-15-2012, 02:55 AM   #4
orion84gsl
I had slotted/cross drilled rotors for a few years. Waste of money. They cost way more than standard rotors and do nothing for performance, at least that I felt during autocrossing, aggressive street driving and Deals Gap. Spend the money on a set of braided stainless brake lines from Racing Beat and some Hawk or Porterfield pads. You'll get your best braking performance out of super sticky tires. Nevermind the hype.
Old 01-15-2012, 03:33 AM   #5
mattallac
mattallac's Avatar
Thanks for all the info ,I bought powerstop rotors cross drilled and slotted ,only paid 68.00 each with free shipping and handling .The price was right so I went for it ,as for pads i went with factory mazda ,I will be using hawk pads that you guys use the next time around.
Old 02-09-2012, 01:47 PM   #6
Rich@SR
SR Race Engineering
Rich@SR is on a distinguished road
Click Me
For those of you thinking about crossed drilled rotors on your track cars (even part time track cars)
Rich@SR is offline   Reply With Quote
Old 02-27-2012, 07:17 PM   #7
dr1vn
dr1vn is on a distinguished road
i have another thought for ya since it was one of my former project. ever consider useing an 84-85 gsl se ? i find them on salvage car auctions and ebay usually for several hundered bux ! you ll get the stronger axels and common wheel bolt pattern plus all disk brakes as well and a limited slip but you will have to swap master cylinders if you had drums /// you might get lucky and trans and engine still in car ...
dr1vn is offline   Reply With Quote
Old 02-29-2012, 06:52 AM   #8
Kentetsu
Kentetsu's Avatar
A couple of years ago (three I think) I bought a full set of rotors from Rockauto.com I went with the cheapest that they had, which was about $15.00 each. I mounted Hawk HP pads at the same time.
Fast forward three years: Over 30k miles on them (racing and daily driving) and they are still in great shape. The pads still have more life left on them than they've used up so far.
Old 04-03-2012, 10:38 PM   #9
dexspeed
dexspeed's Avatar
dexspeed is on a distinguished road
www.kvrperformance.com
I have not yet used their rotors personally, but know several people that have and are quite impressed.
I do however use their brake pads, which I would highly recommend.
dexspeed is offline   Reply With Quote
Old 04-04-2012, 01:35 AM   #10
mattallac
mattallac's Avatar
powerstops part # was wrong so I went with the powerslots and they seem to look pretty good , and thanks for all the good advice everyone>
