Old 04-05-2008, 09:23 AM   #1
Rotary_Rocket_87
2nd Generation Freak
Rotary_Rocket_87's Avatar
Rotary_Rocket_87 is on a distinguished road
Pineapple Racing Graphite Mani Gasket?
I was just browsing through their site and found this.
http://www.pineappleracing.com/index...PROD&ProdID=78
Has anyone used them before? How do they compare to the OEM gasket? At half the price, and being from Pineapple I think it would be worth trying.
'87 TII- full emissions removal, a/c removed, FPD removed, dual 12" e-fans, Rotary Performance FCD, ACT unsprung 6 puck w/ Xtreme PP, custom open 2.5 inch exhaust, custom clutch pivot ball, K&N cone filter, TB mod, RB downpipe, motor blown 8/7/09
'94 Mazda B4000- POS beater truck, stock
"The easiest way to fail is to never try." - Me
Rotary_Rocket_87 is offline   Reply With Quote
Old 04-07-2008, 10:44 AM   #2
classicauto
crash auto?fix auto
classicauto's Avatar
I heard about someone using it once before and had to re-torque it a few times and also noted a funny smell for the first few hundred km's that was presumably the gasket heat cycling.
Personally, I've never seen a stock one fail, and have re-used 10 year old ones and never had a problem. Thats one factory piece that doesn't need re-engineering. Only reason to buy a different type is money, and at that point the product may not work as well.
Old 04-07-2008, 02:02 PM   #3
Rotary_Rocket_87
Yeah, the reason I am asking is because the stock one failed and I can't afford a stock one at the moment. I have read alot about how the stock gasket is reuseable and should outlast the life of the turbo, but I think that one of the previous owners must have taken off the turbo and reinstalled the gasket incorrectly (causing damage).
I think that I am going to try the graphite one, and if it fails it fails. I doubt that Pineapple would sell an inferior part. At least we will get some good information regarding the durability of this part.
thanks for the info Classic.
Old 04-07-2008, 03:03 PM   #4
classicauto
crash auto?fix auto
No problem. I'm sure it'll last alright. They do make good stuff
Old 04-08-2008, 07:33 PM   #5
Boostmaniac
I don't think graphite gaskets are re-useable normally.
None of the ones I have ever used on various projects have been anyway.
