Old 12-28-2011, 03:45 PM   #1
SPiN Racing
SPiN Racing's Avatar
SPiN Racing is on a distinguished road
DGRR 2012 To Do List
SO I figured I would start the thread this year, as we have usually had one!
Replace trailer lights, and all new braketry (thanks neighbors with riding mower)
ON the Dually: Both front tires replace
Front Steering stabilizer
On the 84 ITA RX-7 (deep breath)
Finish the front wheel spacers/adaptors on the mill/lathe
Finish the front brake caliper mounts
button up the front brakes
swap out the rear brakes for TII brakes also
rear axles
fabricate rear spacers/adaptors
decide if I am going to replace the damaged front fender, and valance.. or go with the Mandeville style GTO Body kit.
(Very Probable .. was the plan till the brake conversion took over)
Balance the reciprocating assy for the 6-port Eprod motor.
Assemble it
clutch cover for 5.5" Quartermaster
install it
wire up Wolf 3D 4.56
Exhaust
(Fairly unlikely)
Take apart the former Jim Bonsi dry sump 675 hp NA hill climb 13B
go over all the parts and re-assemble
install
wolf
exhaust
Scott Neville
1984 ITA (converting to something meaner)
1984 13B (Wolf 3.x)
1986 EP (Wolf 4.56)
1991 (Stockish engine, Wolf 3.0)
2005 RX8 Auto (Wife mobile)
Life=counting the time till the next race...
SPiN Racing is offline   Reply With Quote
Old 12-28-2011, 04:20 PM   #2
1. Pull car out of garage.
2. Put fuel in car.
3. Check car is good on fluids.
4. Drive car to deals gap.
There's a couple more I'll throw in there, but I don't have the energy for perfection right now.
Old 12-28-2011, 05:29 PM   #3
I'd add my list, but I did that last year and ended up blowing my engine and didn't have enough time to be ready for DGRR. So...yeah. lol I'm MAKING it this year dammit.
Old 12-28-2011, 06:02 PM   #4
It would be awesome if you did Eric, so worth the trip and I know there SHOULD be a few cars coming from out west as well. Definately make it if you can, if not, fly out east and drive down with us.
My list
FC - Pull engine and balance assembly, new seals as needed
Plug hole on center iron
Stud Kit
Repair belly pan
Powdercoat front bumper supports
Build water/meth tank where spare tire once lived
Mount pump
plumb pump
wire pump
Restrict oil feed line for turbo's
Pull dash and install RedBull holders
Foam all the dash bracing to quite it down
Tranny tunnel rubber for 6-spd
Fiberglass the old holes for some carpet tiedowns
"Deal" with the rear carpet
New front brake rotors
New front pads, two sets
Dial in traction control
Dyno for 21psi
Then go pass emmisions
FC 'Vert
Full TII swap
crack, inspect and rebuild engine
swap tranny
swap rear end
new brakes all 4 corners
New master cylinder
New clutch hydros
Rebuild turbo
Fabricate water to air intercooler
Plumbing for all of it
Install and wire Haltech PS2000
New fuel pump
Different fuel filter
New fuel rails and Reg
ID 725/725's
FFE trigger kit
Paint bumper, FL Fender and hood
Battery relocate
Efan install and build proper shroud
Wire tuck in the engine bay
Install stereo, new head unit, new Amps, new sub
Re-Powdercoat Work VSXX rims and polish barrells
Pretty sure that's it
Oh, dyno... shooting for 280+ on stock turbo
Miata
Find Miata
Get $$,$$$
Buy MoTeC M84
Pull old engine
Rebuild 13B-REW, cryo, stud, Balance and install with RX8 6-spd
Wire M84
Install GT35R
VMIC
Dyno
Trailer-
Get hubs machined to accept 'Vert wheels
Install battery and wire that bitch up
Plug holes on trailer frame and re-drill/re-wire for more attractive lights
New right size coupler
Tag it.
Yup.... there's my list
Old 12-28-2011, 08:28 PM   #5
Well Zico SAYS he's definitely going this year, but we'll see if we can finish his car too haha. And one other person is coming whether his car is ready or not, and we may have one more coming with us. Once I know for sure that I have leave approved I am putting my money down.
Old 12-28-2011, 08:37 PM   #6
A lot of WTFs on your list B -
1st... Haltech, you feeling ok? I have no issues with haltech, but running anything than Motec in your camp is like cutting off the little toe - you don't really need it but you feel damn good when it's there.
2nd... rotary miata???? seriously??? I hate you...
Old 12-28-2011, 09:07 PM   #7
SAWEET! Can you shoot yourself in the toe or something?
Yup, going in Mom's 'vert. Don't need a MoTeC to run a stock turbo stock redline non high-strung rotary. I would've gone with the Micro-Tech for cost and ease but it doesn't have the outputs or logging that I require. I want to log Air temps pre and post intercooler and coolant temps pre and post intercooler and oil temps pre and post oil coolers.... just shut up
As for outputs.... can't really depend on her to watch the gauges and even at that they are less than accurate. So I'll be using some outputs to trigger LED warning lights. Can't do that with the Microtech.... also, the Haltech has the "Engine Saver Function" which could come in handy. I'm actually debating putting the OMP back on because I'm not entirely sure she'll remember to pre-mix the damn thing.... even though there will be a case of pints of premix in the trunk, it's getting her to remember to do it.... so yeah.
Not for me, for the old man.... here's the kicker, I'll be paid to build most of it, and tune it, and test it But yeah, GT35R 6-spd MoTeC Miata
He want's it done by late March... actually he wants it done by late feb so he can ship it to Sebring to go plat... I laughed at that timeframe
Old 12-28-2011, 09:12 PM   #8
Thats pretty sweet though on the miata - one of my ultimate bulids if I ever had the chance to do it. I may have to make a trip up there when it's done so we can see how it rides before getting it shipped off!
Agreed on the Haltech over Microtech. You'll have your fair share of Haltech experiences in your new spot at Dave's... matter of fact, pretty sure you're getting one delivered in the next few weeks, lol...
Old 12-28-2011, 09:27 PM   #9
It ain't making sebring I can tell you that... first time it'll be on the track will more than likely bee 4/16 and 4/17, and I'll be there... it the Pre-DGRR track day!!!!
I can't wait to get that Haltech... hell my new 2000 will be here tomorrow... I've had enough experiences with E6Kraps to want to shoot myself over it. My how things have improved. THe PS2000 and the 1000 that are getting delivered should be a dream to tune compared to those things
Also of note.... the most used tool in the Dyno room is my multimeter. Seriously. There are more wiring problems to fis than anything else. The one I pulled in earlier tonight had the MAP sensor wired backwards. So when it fired up it was being fueled for 30psi Fucker actually ran too. Fixed that problem and now it won't start.... Oh well... hit it tomorrow.... sleepy time now...actually time to go home and eat.
Will you be accompanying the deliver of said haltech in the coming weeks?
Old 12-29-2011, 12:34 AM   #10
Well, I'd try that, but knowing my luck they'd say "well you can't drive anyway, so stick around here and do some paperwork"..ARGH!!!! lol I called back today, so I should know something by tomorrow.
Old 12-29-2011, 10:20 AM   #11
N.RotaryTech
Home-brew Rotary
N.RotaryTech's Avatar
Plan A: The FB.
Basically rebuild every part of the FB.
Rebuild 13b HBP motor
Find out how to get the 13B engine an trans installed.
Redo interior
Upgrade suspension
Upgrade brakes
Paint exterior
There's also going to be a lot of fabrication going on.
Plan B: The FC.
Depending on how the FB is coming along, like if its not going to be finished:
Rebuild oil-leaking turbo again
Reinstall turbo setup
Find out whats causing the light throttle issues and fix it.
'87 RX7 GXL, Rest In Pieces.
'94 Ford Ranger, daily.
Old 12-29-2011, 12:02 PM   #12
Classified
Old 12-29-2011, 06:37 PM   #13
Well I registered a bit ago, so here is my list, although not all inclusive. I'll try to finish as much as I can, but as long as the car is running and it's reliable enough to drive, I will be going whether everything is done or not.
-Install new turbo with new manifold, downpipe (need to get DP and mani made still), and wastegates
-Make new VMIC with new mounts
-Make new mounts for radiator
-Duct IC and radiator
-Install new hood, duct VMIC through hood
-RS-engineering anti-surge system
-Figure out if engine is burning oil (or if it's the current turbo) and rebuild if needed
-Might install aerocatch hood latches, or maybe old style, depending on how bad hood is flexing
-Install oil catch can (once Adam finishes making it lol)
-Make undertray and install ducting to brakes
-Possibly install new FEED bumper
-Install Tweakit diff brace if it's finished in time
-Possibly install tranny brace
-Put on new wheels
That's pretty much it I think, those are the basics anyway.
Old 12-29-2011, 10:43 PM   #14
orion84gsl
On the FB:
Install RE-Speed TII brakes all around with 5x114.3 Moser axles.
Install new aluminum rad. Probably have to do some custom bracketry for this since it's thicker than the stocker so the fan will hit the front pulley and the fan won't fit in front because of the sway bar. A little FC style angle is in order.
(Maybe) Make aluminum inner door panels and redo front speaker pods.
Buy and install the following:
PERFECT wheels.
New tires.
New better seats.
Fender roll/corner balance/alignment
If money and time remains, new exhaust then dyno tune. If not then just dyno tune with the RB exhaust.
Old 01-04-2012, 12:46 PM   #15
SPiN Racing
stock test strut.
Thats this weeks evening activity...
3 of the 4, 1.5" thick billet Steel disks have the centers bored to be hub centric.
A mandrel is turned on the lathe so I can put it on my CNC rotary table to get all the holes milled out properly.
Also the surface needs milled down to 1" thick, leaving a .5inch thick center section to turn in the lathe and make it hub centric for the rim as well.
Scott Neville
1984 13B (Wolf 3.x)
1986 EP (Wolf 4.56)
