Old 12-23-2011, 10:28 AM   #1
Raksj04
I have Ultra power in me.
Raksj04's Avatar
Good power soucre for Gauge.
I have a PLX wideband that I was planing on installing today. I was wondering where I could wire it up besides the cig lighter. I already have a Gauge hooked up there and I don't want to add any more to it. Also what wire is the O2 sensor for the ecu? I would like to mount the control box inside the car and I am not sure if I have a connect issue with the wiring from the stock O2 to the ECU. It is a S4 base with a JDM turbo motor with a 332 ecu and the N/A wiring harness.
Old 12-23-2011, 01:00 PM   #2
Add a fuse. Just run a new dedicated wire.
Old 12-23-2011, 01:03 PM   #3
Raksj04
Raksj04's Avatar
But wont it be on all the time? A wire from where?
Old 12-23-2011, 01:16 PM   #4
mazpower
Rawr Bearclaw
mazpower's Avatar
mazpower will become famous soon enough
Do like My5ABaby says, run a dedicated wire from the battery, fused of course, but to an automotive 30 amp relay. Run the signal wire to activate the relay from your cigarette lighter feed and run your wideband and your gauge from that relay. Much cleaner and the safe way of doing it - widebands can draw a bit of power because of the O2 heater.
Illicit Performance
Rotary building, porting, tuning, chassis dyno services
www.illicitperformance.com
mazpower is offline   Reply With Quote
Old 12-23-2011, 02:29 PM   #5
That works, but it's the hard way to do it. Look below. I have a wideband, radio, and extra cigarette lighter (phone charger) run via Add a Fuses.
You Add A Fuse http://www.amazon.com/Bussmann-BP-HH.../dp/B000GKEXK2 They're sold at Autozone and stuff.
If you plug it into the correct slot it won't be on all the time. When in the car I think it's the bottom couple of rows (on the right in this pic).
Old 12-24-2011, 05:06 PM   #6
Raksj04
Raksj04's Avatar
Does any one know which wire is the O2 sensor for the ecu?
Old 12-24-2011, 06:56 PM   #7
Check the factory service manual.
Old 12-24-2011, 09:08 PM   #8
Raksj04
Raksj04's Avatar
If I am reading the fsm right it is a gray wire (Gy) or pin 2D on the ECU harness
