Old 12-21-2011, 09:56 PM   #1
jimstaz
jimstaz's Avatar
jimstaz is on a distinguished road
fiberglass hoods? where
I found a few style fiberglass hoods for the 8... they look too much like the stock.. i do not want carbonfiber and thats all i find. is there any websites out i may have missed for me to find a fiberglass hood that might catch my eye? thank you for the help.
jimstaz is offline   Reply With Quote
Old 12-22-2011, 05:34 AM   #2
Sephitrask
BOILED PEANUTS!!!
Sephitrask's Avatar
Sephitrask is on a distinguished road
Why do you want a fiber glass hood over carbon fiber? The stock hood weights less than carbon fiber, fyi. Is there a style you are going for? I would just get the CF one....
www.rotarycarclub.com
"The way a Rotary engine makes power is ferocious, much like having a chainsaw under your right foot."
Sephitrask is offline   Reply With Quote
Old 12-22-2011, 10:16 AM   #3
Best hood in fg in my opinion is the autoexe. You can see it at corksport.com. Cf hoods are cheaper though and you can always paint them. The oem hood is the lightest thus far... But does not provide good heat relief. Be careful of vented hoods that don't have proper drains for rain as it can direct water onto your steering rack controller and cause shorts...
Old 12-22-2011, 07:11 PM   #4
jimstaz
jimstaz's Avatar
i did not know this about vented hoods.. is there certain style hoods that are non for that or to stay clear of.. i do drive in weather alot.
Old 12-22-2011, 08:44 PM   #5
Its a case by case basis unfortunately, just make sure it has a rain guard... if you do find that its draining incorrectly, you can use some tubing or hose to reroute the water if needed...
Old 12-23-2011, 07:28 AM   #6
Sephitrask
BOILED PEANUTS!!!
Sephitrask's Avatar
The plugs for the rack are sitting on top of the rack, right behind/below the air box. IMO you should be fine as long as those are not drained on, it has been proven that they don't mix well with water. You could make some kind of cover for it, then it wouldn't influence your hood selection. I wouldn't worry to much about water in the bay, it is pretty exposed anyway, and many cars have vents without guards. For example, the Evo's rain guard didn't stop the water from falling into the exhaust manifold and turbo, it only blocks view into the engine compartment. (excluding the Evo x, I don't know about that)
Old 12-23-2011, 05:05 PM   #7
We have a hood on one of our RX8s that caused the steering rack to fail, so thats why I'm mentioning it. Its not a huge issue, but just running around all day in the rain with an open hood CAN cause issues so I think its best to protect against it.
Old 12-25-2011, 04:07 PM   #8
jimstaz
jimstaz's Avatar
i have been looking at some carbonfiber hoods and they actually look good on some of the black RX8s.. thank you for your time guys and ill be careful on the type of hood.
