Old 11-19-2011, 09:56 PM   #1
80leathersport
80leathersport is on a distinguished road
Powder coating motors
I am thinking of trying to powder coat my housing andand irons. Has anyone powder coated their housing and irons before. Does heating them up to bake cause any problem
80leathersport is offline   Reply With Quote
Old 11-20-2011, 01:24 AM   #2
DriFD3S
DriFD3S's Avatar
I also want to have my andand irons powder coated,
seems legit! =)
JDM True Story.
JDM FTW.
Old 11-20-2011, 02:43 AM   #3
80leathersport
I was told that the baking temp for the powder can't be over 350 so it has to be low temp powder but I don't know who sales it.
Old 11-20-2011, 12:58 PM   #4
Zach power coated his and hasn't run into any problems.
Old 11-20-2011, 05:29 PM   #5
JDriftM
Dedicated Rotorhead
JDriftM is on a distinguished road
My entire engine, irons, rotor housings, all of it, is powdercoated, ported, assembled, running, and running like a bat out of hell. I have absolutely zero issues.
In February, I will begin offering this service. Price will be competitive, and completely to order, no "only" color options, any color, any combo.
Pics for proof.
DGRR 2013.
JDriftM is offline   Reply With Quote
Old 11-20-2011, 06:47 PM   #6
I powdercoated a junk housing for display purposes once, flash @ 450, bake @ 400. The chrome lining started to seperate from the steel liner. Good thing it was already a junk housing, becuase it definately was afterwards. So no, it's not "legit" unless you use the previously mentioned low temp powder
Old 11-20-2011, 11:58 PM   #7
80leathersport
Where did you get your powder from
Old 11-21-2011, 10:00 AM   #8
IH8DSM
IH8DSM's Avatar
We have the low temp powder you just have to figure out the colors you want between charles and jess we shouldn't have a issue.
Old 11-23-2011, 08:50 PM   #9
JDriftM
Dedicated Rotorhead
Exactly, low temp powder and you're good. The powder I used was rated at 400* but I turned the temp to 300* and doubled the time in the oven. I've opened the motor up since the powder coat, and I've had zero issues. As long as your surface is clean, the powder will stick, my brother has powder coated a valve cover and it was, at the time, too big for our oven, he used a heat gun and simply heated the thing from the outside only. He's had no flaking since then.
DGRR 2013.
