Old 10-27-2011, 06:32 AM   #1
j0riakh1
j0riakh1 is on a distinguished road
86 turbo starting issues. Trying to sell!! Please help me out!
I have a 1986 gxl that has been rebuilt, with an extended street port and the addition of a turbo from an 88. The car is all hooked up. There are so many
Mods I'd have to email them. I'm having trouble starting the car. Like it's not getting proper fuel at first or something. I crank and it turns over and for it to start, I have to vigorously press the gas over and over. Sometimes I may have to do this 2 or 3 times. Also once it's started. I press the gas and it stutters as if it wants to stall for a second or two. Then finally responds. I don't know what's going on. I'm trying to sell the car but it will be difficult if I can't make it start! If you have ANY ideas or advice please contact me. Thank you!
j0riakh1 is offline   Reply With Quote
Old 10-27-2011, 06:48 AM   #2
N.RotaryTech
Home-brew Rotary
N.RotaryTech's Avatar
So what size injectors do have installed?
What fuel pump?
What ECU upgrade? Haltek? Megasquirt? etc. Or is it stock?
'87 RX7 GXL, Rest In Pieces.
'94 Ford Ranger, daily.
Old 10-27-2011, 07:25 AM   #3
1) Find a competent shop that can take care of this headache.
2) Fork over the money to get it fixed.
Seriously, I don't know why people get into projects that are in over their heads.
Dump the headache and take the loss.
You seriously think you're going to get free advice to solve all your problems without paying us a cent and then make your money?
The possibilities are endless.
Even several hundred emails isn't going to solve the problem.
It can be anything from a blown engine to electrical problems to who knows what...
Old 10-27-2011, 12:16 PM   #4
Raksj04
I have Ultra power in me.
Raksj04's Avatar
wow. I thought this forum was to try to get help and help others.
Do you have a compression tester? if you do do a compression test. If you have a boost get check to see what the vaccum is at once it is started. when I swapped in my Turbo motor I had issues with it starting because I had a lot of vaccum leaks.
Old 10-27-2011, 04:06 PM   #5
funkjaw
funkjaw is on a distinguished road
Please provide more info about the car. What fuel setup, EMS, etc. etc..
funkjaw is offline   Reply With Quote
Old 11-22-2011, 05:07 PM   #6
Wms10th
Happy to be here!
Wms10th is on a distinguished road
I don't know if you are aware of it, but, these things flood quite easily, especially if you have the stock ecu. That's why everyone is asking what setup you have in order to help you.
1988 10th AE
Lucky 7 built Street port,S5 rotors and housings, CA smog legal,
HKS Sport turbo, FMIC,Pinapple Racing Deep oil pan, Rteck 2.1,720/1000 inj, HKS EVC-S, HKS 80 mm big exhaust, AEM wideband afr meter, suspension techniques springs and bars,HKS adjustable shocks.
Wms10th is offline   Reply With Quote
