Old 10-24-2011, 07:44 AM   #1
Jonathan3009
Jonathan3009 is on a distinguished road
Best place to fit oil/water senders? impressions pros/cons
Hi all
i recently bought a jdm rx7 (stock RHD ) and im gonna start with the reiability mods first of all im gonna replace the AST and want to install gauges...
My problem is... I don't know where to fit the senders... i was planing on get a sandwich and fit oil senders there... but I've read somewhere that with time that location tends to leak...
Im want to install (boost, oil press/temp, water temp)
can you help me?
thx!
Jonathan3009 is offline   Reply With Quote
Old 10-24-2011, 01:05 PM   #2
Force13b
cxxxx|::::::::::::>
Force13b's Avatar
I used a sandwich plate for the oil it's been there for 2 yrs now and i don't have any leaking. For water temp i used hose adaptor and i'm not real happy with it. It reads about -10°F from the stock sensor and it doesn't react until the t-stat opens. If your car is stock T into the throttle body hose, you can get all the parts you need from the hardware store for about 10$. If you want to go big you can drill and tap your water pump housing. Boost is easy there are 2 nipples on the UIM you can tap into.
Old 10-24-2011, 02:20 PM   #3
Supernaut
Supernaut is on a distinguished road
I've done something similar for the water temp sender. I used glowshiftgauges hose adapter though, same with the oil filter sandwich. None of which have been giving me problems.
-93 Spirit R Replica built @ IRP/S1. S1 tuned
Supernaut is offline   Reply With Quote
Old 10-24-2011, 04:28 PM   #4
Signal 2
Viable Fossil
Signal 2's Avatar
Another vote for using the throttle-body coolant line for the temp sender. Easy, inexpensive, accurate and you get readings as soon as you start the car, not just after the t-stat opens.
It's also easily reversible if you ever decide you don't need it anymore.
Picture of mine from some years ago if it helps....
Jim
VR R1 FD
Old 10-24-2011, 06:37 PM   #5
Jonathan3009
Thank you so much!!!! it helps a lot!! because really im very lost on rotaries...
so if i use the sandwich from prosport gauges for example... will be fine? due to im very worried about leaks or something...
Old 10-25-2011, 12:52 AM   #6
FC Zach
FC Zach's Avatar
I've heard of people drilling and tapping the oil cooler line banjo bolt to accept a sender. Cheap alternative, that's unless your running AN style fittings and if so then nevermind.
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 10-25-2011, 10:25 AM   #7
Signal 2
Viable Fossil
Signal 2's Avatar
I've never monitored oil temps. Personally I don't see the need to monitor coolant temp AND oil temp. All those gauges in the car start to look silly IMO. For oil pressure I use the stock gauge. OEM senders are a little notorious, but keeping the connection clean has worked well enough for me. I don't think these cars have many oil related failures...unless something aftermarket fails and leaks.
Jim
VR R1 FD
Old 10-25-2011, 11:40 AM   #8
Force13b
cxxxx|::::::::::::>
Force13b's Avatar
All 3 in 1 gauge, water temp, oil temp, oil pressure
http://rotarycarclub.com/rotary_foru...ad.php?t=14212
Old 10-25-2011, 01:09 AM   #9
Trout2
Trout2 is on a distinguished road
Sandwich plate works fine with proper o-rings. I used the Racing Beat one on a first gen for 7 years then a Pineapple one for 5 years and now the REspeed one for 1-1/2 years. No leaks.
For water, the sender with my SPA gauge works in the factory sender location on the rear iron.
Jack
Trout2 is offline   Reply With Quote
Old 10-25-2011, 12:26 PM   #10
Jonathan3009
That gauge looks really good.... I found something similar in Depo racing gauges... 4 in 1 if i remember correctly... My only problem is that I live on spain... so we're a bit far to make a GB...
well, im gonna get some gauges... with warn, I'm decided to use the prosport filter adapter for oil press/temp senders and for water temp I'm gonna use the TB coolant hose...
Just I've pending where to attach the boost pressure gauge....
btw... can you recommend any good price/quality gauge brand? I'm looking for some temporal solution... not looking directlly for defi or greddy gauges =D
but if you have them used or something we can talk
thx to all!
Old 10-25-2011, 12:52 PM   #11
Force13b
cxxxx|::::::::::::>
Force13b's Avatar
thx to all!
I ordered that gauge from Hong Kong so that gauge is a lot closer to you then me in the states. My first water temp gauge was a glowshift it was cheap and it did the job. They are very similar to Prosport gauges.
For boost there should be 2 nipples off the passenger side (LHD car) of the Upper intake manifold. 1 will go to your BOV the other you'll use for a boost gauge. (see image where it says boost gauge)
I went with RE Amemiya center column gauge. I'm sure i spent a lot more just because of the name on it.
Old 10-25-2011, 01:03 PM   #12
Supernaut
I recommend PLX gauges. They have many different types of displays including a 4 in 1. You can also customize the background.
Old 10-25-2011, 01:38 PM   #13
Signal 2
Viable Fossil
Signal 2's Avatar
Good to know I'm not the only one wanting to minimize the number of gauges. Having one with multiple displays is kind of cool, as long as it's simple to go from one to another on the fly.
But monitoring both oil and coolant temps still seems redundant. What will oil temps tell you that coolant temps won't...or vice-versa?
Jim
VR R1 FD
Old 10-25-2011, 02:16 PM   #14
Jonathan3009
I've found something similar... and some time ago... there was a gb to spain for those gauges...
http://www.youtube.com/watch?v=IqouOlz74KY
i think for many rx7 users that gauge can be a good option... the only bad thing I've found is they don't have warn/peak alert...
they're cheap and seems like they're good quality
but im still opened to your advise and feedbacks about brands
Old 10-25-2011, 02:39 PM   #15
Force13b
cxxxx|::::::::::::>
Force13b's Avatar
Wow that is exactly what my gauge looks like. I'm sure it's just re-branded very cool. Good to know it was a pain to get the Sgear gauge.
http://www.deporacing.com/product_1....key=342&type=B
