Old 10-20-2011, 08:46 AM   #1
Raksj04
I have Ultra power in me.
Raksj04's Avatar
Coilover install questions.
I ordered Godspeed coilovers and I was wondering how I should setup them up itinitally and how soon to get anlingment. I dont want the car to pull funny on the street or for my tires to wear bad.
Old 10-20-2011, 10:23 AM   #2
tyler
I find it easiest to set it.to the hieght you want then put the dampaning in.the.middle so you can go sorter or harder, after you have your settlings how you want then get.ur alignment. It be best to.get.it within a week or two but you maybe able stretch it gota if necessary. Take extra tike to break in ur.Godspeed coilovers as they have a tendency to blow fast, and remember if you drop more.then and.inch.or so.in.the rear you will need to adjust The rear camber
Old 10-20-2011, 10:39 AM   #3
Raksj04
Raksj04's Avatar
How do you break them in.
Old 10-20-2011, 11:00 AM   #4
If your suspension is stock, then you cannot lower the FC that much.
Lowering the ride height will significantly change the rear camber (first).
You end up with excessive negative camber (in the rear).
You need either a rear camber adjust bar and / or a pair of links that adjust the links at the front of the rear suspension subframe.
In general, you do not need to "break in" suspension components.
Old 10-20-2011, 12:06 PM   #5
Raksj04
Raksj04's Avatar
Which links are better, the ones from MMR that allow each wheel to be adjusted or the single bar one?
Old 10-21-2011, 05:29 AM   #6
Everyone will tell you differently, but I prefer the single one.
Old 10-21-2011, 11:10 AM   #7
infernosg
IT'S ALIVE!
infernosg's Avatar
I would say if you could get both. Use the single bar to get you to the general number you want and use the individual sides to even things out.
I have the AWR units (similar to MMR) and they work well. I wish they had a little more adjustability because I have my coilovers at maximum height in the rear and I can't go lower than -1 degree of camber. I'd use the single bar but I have solid (delrin) mounts in the subframe.
Old 10-27-2011, 04:23 PM   #8
funkjaw
funkjaw is on a distinguished road
Single bar doesn't allow individual camber adjustments. I like the idea mentioned about having both myself.
funkjaw is offline   Reply With Quote
Old 10-27-2011, 04:29 PM   #9
Raksj04
Raksj04's Avatar
I do have the MMR drivetrain mounts.
Old 11-04-2011, 12:21 PM   #10
Raksj04
Raksj04's Avatar
Ok so I got them in the mail today and they came without instructions. I have no idea how to set these up and have the car drivable. I can get them on but I am unsure what will happen. Any one install these before?
Old 11-04-2011, 02:44 PM   #11
infernosg
IT'S ALIVE!
infernosg's Avatar
Here's a couple pictures of my AWR units. Not the same as the MMR ones but maybe this helps clarify?
Old 11-04-2011, 02:59 PM   #12
Raksj04
Raksj04's Avatar
oh I mean I got the coilovers with out instructions? my bad. They are godspeed project brand
Old 11-07-2011, 10:10 AM   #13
infernosg
IT'S ALIVE!
infernosg's Avatar
Coilover install is pretty straightforward. Remove old spring/strut assembly and replace with coilover assembly. Be sure to torque everything down to the required specs; you don't want this coming apart on the road. You'll have to play with the height settings to ensure an even ride height and you'll have to guess at camber/toe unless you have means of measuring them.
Old 11-07-2011, 10:39 AM   #14
Raksj04
Raksj04's Avatar
the only problem i see so far is there is no clip to hook the brake line to on the coilovers
Old 11-07-2011, 11:35 AM   #15
Raksj04
Raksj04's Avatar
I installed them being near the same length as the OEM ones at 1st and I realized, as I was lowering the lift, these are going to be high as hell. I can fit a fist and three fingers in the back. I ran out of time to put the fronts on and adjust the back. I will post the pics when I find my camera.
