Old 10-16-2011, 07:32 PM   #1
TS87FC3S
Ask Me About My WANKEL!!!
TS87FC3S's Avatar
TS87FC3S is on a distinguished road
83 small axle question?
how much power can this rearend hold, running an auto trans, turbo v8, between 450-500 wheel.. im guessing it prolly wont hold up
1984 Rx7 Gs - stripped interior re speed coil overs, tokico blues, re speed crossmemeber and mustang rack, diamond star racing wheels
1988 Rx7 Se - Sold
1988 Rx7 GXL - Sold
TS87FC3S is offline   Reply With Quote
Old 10-17-2011, 08:20 AM   #2
730RWHP12A
if you keep stock tires on it you will be ok, you put some decent size wheels and tires the rear end wont last long at all..
pick up a mustang 8.8. they are cheap and work well.
rotaryshack.com
Old 10-17-2011, 12:04 PM   #3
TS87FC3S
TS87FC3S's Avatar
might have found a fox body 8.8, can i just cut my mounts off and weld them to the 8.8? and will the 8.8 in stock form hold up to what i plan to do (will be running slicks and 2800 stall)
1988 Rx7 Se - Sold
1988 Rx7 GXL - Sold
Old 02-19-2012, 05:43 PM   #4
sa22c
sa22c is on a distinguished road
I can run high 11s on the standard gearbox and rear end. I'm using 205 wide circuit radials to do that.
In theory my car is only about 1 second off its real potential and it is a lot of work and money to put in a TII gearbox and stronger differential.
I will probably do it eventually because I want to learn how to drive / launch like a pro.
sa22c is offline   Reply With Quote
