Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > SakeBomb Garage
SakeBomb Garage SakeBomb Garage "OEM appearance, uncompromised performance"
Old 10-15-2011, 03:33 PM   #1
3RotorMotor
3RotorMotor's Avatar
3RotorMotor is on a distinguished road
Cool Dual oil cooler kits GB#3 - SakeBomb Garage
SakeBomb Garage
is once again proud to present: The best damn twin oil cooler kits available!!
Golden ticket edition!!
We wanted to do something fun for this group buy :nod:. If we reach 20 people or more, we will randomly put a golden ticket in on of the boxes! If you happen to be the lucky recipient of this ticket, you will be able to redeem this ticket for the golden eggs (which by the way are worth over $900 dollars!!!). We will provide more details on this as the end of the GB draws near
**$150.00 GB discount**
Take $150 off your total
(Expires July 23)
What you can expect from our oil cooler kits:
  • Maximum cooling efficiency to protect our already hot running motors, and eliminate overheating concerns by taking significant load off of the water cooling system.
  • Direct bolt-on, with no fabrication, modification, or custom work involved
  • OEM look and fit
  • Two cooler sizes: Different oil-cooler capacities to fit your car's cooling requirements, and your budget.
  • Coolers can be swapped out at any time to upgrade capacity, and coolers will work with '93+, '99 spec, and most aftermarket bumpers.
  • Over-Engineered: Pressure and temperature ratings for ALL of our lines and fittings vastly exceed the maximum pressure and temperature ever generated by the oiling system, to ensure durability and longevity.
All of our kits include:
  • Black Setrab oil coolers
  • Mocal 180 degrees oil thermostat
  • Lightweight aluminum mounting brackets
  • Stainless steel mounting hardware
  • All lines (rubber/stainless/nylon racing) come pre-assembled and pressure tested with high quality (and subtle looking) black and silver Mocal fittings (only the best).
  • Aluminum -10AN Spanner (Wrench) included to tighten down your fittings.
  • Step by step instructions
Options and Pricing :nod:
25 row left, 19 row right
Coolers
Street Kit (Base Kit)
$1080
Comes with twin 19-row Setrab coolers, High-Pressure Black rubber hose (OEM look) with high quality black and silver Mocal end fittings pre-installed. Included with every kit is a -10AN aluminum spanner (wrench) to safely tighten the aluminum fittings without damaging them. Everything you need to install the coolers on your car is included, down to every last nut, bolt, washer, or spacer... and even the wrench! (*As our brackets are designed to accept both 19-row or 25-row coolers, they can be upgraded to the larger capacity coolers at any time!)
Track Kit + $150
Upgrade to 25-row Setrab cores. Even higher cooling capacity then our twin 19 row kit. We have reports of customers staying out ALL DAY at the track without any sign of rising temps! This setup really is cool! Don’t cut your track day short. Also 20b and high-HP 13b's <nobr style="color: darkgreen; font-weight: normal; font-size: 100%; font-family: verdana,geneva,lucida,'lucida grande',arial,helvetica,sans-serif;" id="itxt_nobr_31_0"></nobr>should consider this setup.
Fitment
‘99 Spec/Aftermarket Bumper + $130
Those of you running a '99 spec bumper or aftermarket bumper will need to upgrade to this redesigned kit so that the coolers clear the bumper and can make better use of the larger inlets. (Please see the *note below)
Line Upgrades
Stainless Steel Braided Lines + $70
Highest pressure and temp rating of all the lines we offer (and they look great!) but care must be taken when routing them as the SS braids can wear into anything they come in contact with.
Nylon Braided Lightweight Racing Lines + $120
Black Nylon reinforced lines, ultra lightweight, high pressure and temp rating (and they look great!). These nylon lines have the benefits of braided reinforcement (like SS lines) but without the abrasion problems and lack of flexibility associated with SS lines.
Stainless braided line option
Lightweight nylon braided line option
*A note about the 99 oil cooler upgrade, and about aftermarket bumpers.
Cost: Unfortunately, the ‘99 coolers needed to be repositioned for the 99 bumper and rebar, and special fittings were required to then clear the headlights. In addition there is a more complex bracket setup required to relocate it to the proper position. For this reason the price of the 99 kit is significantly higher. This is directly due to the cost of the extra parts... we actually take a loss on the 99 “upgrade” for this reason, but it was the only way to make them fit the 99 bumper, be positioned to make more efficient use of the larger bumper inlets, and also work with the stock 99 fog lights.
Aftermarket bumpers: We also engineered a small amount of adjustability into the brackets in hopes that people with aftermarket bumpers could adjust the position of the oil coolers to work with their bumper. We obviously could not test the coolers with every aftermarket bumper out there (so we cant guarantee 100% that they will fit without modification) but more than likely, there is enough adjustability to fit the majority of aftermarket bumpers out there. You have an even better chance if your bumper uses the 99 lights or similar, as those bumpers were typically designed to work with the stock 99 cars’ oil cooler setup (which is basically how ours fits).
[CENTER]**GB Instructions**
Please add your forum username, and any kit options you want to the list below.
Deposit: Please send a $50.00 non-refundable deposit to hold your spot in the GB. You can not sell your spot on the list either. At the end of the GB (July 23 rd) final payment must be submitted.
OR
Payment in Full: If you are ready to make your complete payment please add +$25 for shipping
How to make a payment: PayPal normally charges us a 3% fee for using their services... Lame. Instead of simply adding 3% onto every kit (in the form of inflated product pricing) we give our customers the option of avoiding this charge by using the $5 flat-fee e-check option. To avoid this charge, please submit payment as an 'e-check'. Here is a quick tutorial -> http://techtips.salon.com/send-echeck-paypal-2927.html
If you choose to submit payment using standard paypal, please add 3% to your totalto your payment. If you wish to submit payment via another method please PM us
Example:
E-Check: Total = $5 + Kit Price + $25 shipping
Standard PayPal: Total = .03 * (Kit Price + $25 Shipping)
PayPal address - sakebombgarage@gmail.com
Thanks,
Dan and Heath
SakeBomb Garage
3RotorMotor is offline   Reply With Quote
Old 10-15-2011, 03:34 PM   #2
3RotorMotor
Old 10-15-2011, 03:35 PM   #3
3RotorMotor
Golden Ticket!
Here's a picture of the golden ticket prize. Again if we reach 20 GB participants, we will randomly place a golden ticket in one of the boxes. If you are the lucky recipient of the ticket you can cash it in for this special golden set of our HID bi-xenon projector headlights ($900+), with bulbs, ballasts, and harness included. We've been told by MANY previous customers that this is one of the best safety mods they have done to their car... "its like daytime at night". This is true modern day state of the art lighting for your FD. More info here -> http://www.rx7club.com/showthread.php?t=915186
Good luck everyone! :ylsuper:
Old 12-05-2011, 08:18 PM   #4
lOOkatme
lOOkatme is on a distinguished road
Is this group buy still active? If so, I would like to get the track kit.
lOOkatme is offline   Reply With Quote
Old 12-06-2011, 02:30 AM   #5
3RotorMotor
There wasn't enough interest over here to run a GB but shoot me a PM or email to sakebombgarage@gmail.com ...I'll see what I can do
