Old 10-12-2011, 01:41 AM   #1
Force13b
cxxxx|::::::::::::>
Force13b's Avatar
Where does this ground plug go, coolant level disconnect
I know it is suppose to plug in behind the power sterring pump area, above ac compressor. I've been searching for like an hour now and it's pissing me off.
Old 10-12-2011, 05:27 AM   #2
DriFD3S
DriFD3S's Avatar
='( I hate when this happens to me man!
GL!
JDM True Story.
JDM FTW.
Old 10-12-2011, 05:40 AM   #3
I believe that's the one that connects to the starter harness. There should be a male spade connector on the starter harness that hooks into that, and IIRC that's the only place where the two harnesses come together. That is the side coming off the engine wiring harness right? You could just ground it to the chassis but it wouldn't do you any good if your coolant gets low lol.
Old 10-12-2011, 10:29 AM   #4
Force13b
cxxxx|::::::::::::>
Force13b's Avatar
GL!
I have all the other plugs hooked up or know where they go this 1 has been taunting me for a couple days now. I'll search for it for a while then move to something else so at least i'm being productive and not spending all my time searching for 1 stupid plug.
That might be why i'm missing it i'm looking on the block for it to hook up. I'll search around tonight. I'm not sure what you mean by the side coming off the engine wiring harness. The next plug below this 1 is the OMP not sure if that helps.
Old 10-12-2011, 06:17 PM   #5
What I meant is the one you're holding is coming from the engine harness right? I just wanted to make sure it was that side and not the wire coming from the starter harness and I'm getting confused lol.
When I first bought my car, that wire was grounded to the firewall and I thought it was normal because I didn't know any better. I didn't know until I got a new(er) starter harness that had the wire I was supposed to hook it to lol.
Have you turned the key on with that wire disconnected/not grounded? It should buzz or beep or whatever.
Old 10-12-2011, 06:18 PM   #6
Please delete this double post. I'm not sure why it double posted, I didn't send it twice.
Old 10-13-2011, 12:51 PM   #7
Force13b
cxxxx|::::::::::::>
Force13b's Avatar
Yes it is from the main engine harness. Check starter harness for connector check.
No the car isn't that far along intake manifold is still not connected or Alt along with a few other things.
Old 10-13-2011, 01:10 PM   #8
lt1_fd3s
WNC Tour Guide
lt1_fd3s's Avatar
look at the wires that split off for the alt from the starter harness... friend's was coming out right there...
any way you can post pics of your starter harness so we can possibly help you find it that way?
FYI: harness that runs on the engine, runs injectors, IAC, throttle, etc is listed as the "emissions harness" by mazda... and the one for the starter, alt, etc, is the "engine harness" =P
Old 10-13-2011, 06:58 PM   #9
OK gotcha. You should find the plug on the starter harness then.
Yeah that's right, it should be just a small wire coming off where the alternator wires are.
Weird that's what they call them, hmmm.
Old 10-19-2011, 10:38 AM   #10
Force13b
cxxxx|::::::::::::>
Force13b's Avatar
You guys were dead on with the starter harness. You can't see it you have to feel down the starter harness and you'll run into it just behind the power steering pump.
Old 10-19-2011, 05:14 PM   #11
Yup! Glad you found it.
