Old 09-29-2011, 03:53 AM   #1
DriFD3S
DriFD3S's Avatar
Winter Storage, what to do...
My FD is about to go back in the garage, for winter,
even though there isn't any snow yet......
But, does anyone here have any FREE ideas, on how to store the FD?
I plan on starting it once a week, and keeping the gas tank full,
the oil in it is less than 2000km old,
should this work fine? or is there an easier, better, JUST AS FREE way to store the FD?
(cheap isn't free, but, sometimes it's just cheap enough)
I already own engine fogger spray, which I bought last winter,
and never used, because I heard it could be bad,
But, that was from the OTHER FORUM.
Thanks guys!!
By the way, what does low oil pressure mean, when my oil is nice and full??...
My engine oil pressure was pretty low on the way home from work,
and even at 6000rpm, it didn't go over 1/3, it seems inconsistent, and sluggish, any ideas why???
I will drive it again tomorrow, and see what happens.
JDM True Story.
JDM FTW.
Old 09-29-2011, 06:13 AM   #2
You could put fuel stabilizer in the tank (Sta-Bil is the most common brand I know of) and disconnect the battery. If you do that and don't start it up, I'd think about pulling the fuel fuse and running it until it dies, that way you get the fuel out of the lines too. Also, depending on how cold it gets there and what your coolant/water ratio is, might want to drain the radiator, just in case. But all that is useless if you want to start it every week haha.
Are you still using your stock oil pressure gauge? If so, there is your reason LOL.
Old 09-29-2011, 08:06 AM   #3
Signal 2
Viable Fossil
Signal 2's Avatar
Stock oil pressure sensors are known to have issues. But if your using a really thin viscosity when it's still relatively warm and/or you have some fuel dilution that will make a difference in what you see at the gauge.
I think if you still have the wax thermopellet in place that will also effect indicated pressure as well.
I prefer a quality battery tender to just unplugging the battery. I leave the coolant full but it's one of the things that typically gets changed in the spring when the car comes out of storage. I typically put the car up on stands and off the suspension. Not saying there's no value to them, but I've never used foggers.
Jim
VR R1 FD
Old 09-29-2011, 10:25 AM   #4
Tell that to the millions of boats that get winterized every year with the foggers.
Fill up gas tank.
Dose fuel with Sta-bil
Drive home
Fog engine till stalls
pull plugs and spra fogger into spark pug holes, rotate by hand to next chamber and repeat, reapeat this 5 more times.
Spray fogger on NEW plugs
put plugs back in
top off rad
store off the gnd
hook up battery tender
don't start until spring.
In spring, change oil, change coolant, turn key
Old 09-29-2011, 01:44 PM   #5
http://aaroncake.net/RX-7/storage.htm
Old 09-29-2011, 02:29 PM   #6
lt1_fd3s
WNC Tour Guide
lt1_fd3s's Avatar
ship car to friend in area with warmer winter and let them drive it occasionally until you want it back?
Old 09-29-2011, 08:04 PM   #7
FC Zach
FC Zach's Avatar
^ what Tray said! I don't mind watching your FD, bring it on down!
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 09-29-2011, 08:52 PM   #8
IH8DSM
IH8DSM's Avatar
No bad zach no fd for you haha
As for the OPs question id say what brian said, that Sta bil is good stuff, also your washer fluid jug make sure its not just water/mostly water it'll crack the reservoir pretty easily if it freezes
Old 09-29-2011, 09:23 PM   #9
Originally Posted by My5ABaby View Post
WRONG! You change the oil AFTER you've fogged the engine, OR in the spring.
Old 09-30-2011, 06:12 AM   #10
DriFD3S
DriFD3S's Avatar
I liked Aaroncake on the OTHER FORUM also,
that is one cool dude.
Thanks for the input guys,
But, I will say this:
SpeedJunkie, thank you.
Signal2, thank you.
TitaniumTT, if I could, I would change my oil before storage, and after storage, I do however need new plugs, so, thank you for helping my justify that cost, I also have an ignition booster that I am scared to touch.
My5ABaby, Good link! /favorited
lt1_fd3s, FC Zach, keep dreaming, but, good idea!
IH8DSM, I also hate DSM's. *brofist*
JDM True Story.
JDM FTW.
Old 09-30-2011, 08:00 AM   #11
Signal2, thank you.
What's the reasoning behind changing it before storage?
Old 09-30-2011, 01:05 PM   #12
Garfinkles Motor Works
Remove the acid build up .
Old 09-30-2011, 05:17 PM   #13
93rx7r1
93rx7r1's Avatar
93rx7r1 is on a distinguished road
Most likely your oil pressure sending unit. They commonly fail. You can try cleaning it or replacing it. A third option is just get an aftermarket oil pressure gauge.
My FD3S Build Thread
2005 Subaru Impreza WRX (daily)
93rx7r1 is offline   Reply With Quote
