Old 09-16-2011, 10:54 PM   #1
dr.occa
dr.occa is on a distinguished road
Carb'd 12A 1985 AE86 Coupe build in the Lonestar State
Picked this rolling chassis up about 2 - 3 years ago in San Antonio. I'll keep the dialogue to a minimum for the time being.
These cars never came to the States in a Levin format so here are snippets of parts to convert the US Trueno to a Levin.
The TRD replica Group A/N2 wing my daughter is holding is obviously just a luxury.
The factory Toyota brackets needed to mount the headlights accordingly graciously provided by a buddy (Aaron Rue a.k.a. Hondarue).
Some of the parts mounted.
I'll be the first to tell you I'm horrible with welding. I'm especially worse when it's with a cheap Harbor Freight wire mig welder.
I decided to try and rig up a hood by using spare flip up head light covers to weld up an appropriate hood. It's going to seem some bondo if I do go with the hood.
More turd welding.
Picked this up for $200 from the same kid I got the chassis from.
Engine bay rattle canned.
Power plant in.
Aero mounted. You rotary guys have some killer affordable rads!
Oil lines ran...
...and cooler mounted.
Then...
Today, I just finished up the DLIDFIS ignition setup. A big thanks to Rotary Car Club (AND RX7Club to be honest) and especially Master Chief from Tulsa Turbo for the wiring and explanation of how it operates.
GM HEI Modules
2 Accel Coils 1 for each leading plug. 1 to the distributor for the 2 trailing plugs.
The hook ups to the magnetic leads in the distributor. I finished up the alternator wiring into the SR5 harness as well as evidenced in this pic.
dr.occa is offline   Reply With Quote
12a, ae86, dlidfis, dr.occa
