Old 09-05-2011, 01:35 PM   #1
ShelbyZ87
ShelbyZ87 is on a distinguished road
Dash and Tail Lights inop
Hey everyone, ran into a problem with my FD's interior dash lights and tail lights not working. I found the tail fuse blown in the fuse box, replaced it and still both are inop. Was wondering if anyone else has had this problem and can help me try to figure this out? Thanks Matt
ShelbyZ87 is offline   Reply With Quote
Old 09-06-2011, 04:22 PM   #2
hades
Lk at btn fuse under hood.
This is going to tear
Old 09-13-2011, 11:14 AM   #3
ShelbyZ87
Sorry its taken me so long to reply back but, I checked all of the fuses and they are all good, I even switched the TNS relay thinking that might of been the culprit, but still no luck so I'm starting to think the headlight switch might be bad
Old 11-16-2011, 02:52 PM   #4
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
I had the same thing happen to me when I was in England. It turned out that something inside the dash had blown and the electricians (though not very good) ended up rerouting a bunch of stuff behind my head unit.
I'd take the car into a reputable auto electrician and ask them to check back there.
'94 Touring - Cursed
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 01-10-2012, 12:28 AM   #5
FC3SDrift
FC3SDrift is on a distinguished road
most likely blew the the dimmer switch were you messing with your radio? theres wire in there for the radio illumination that will blow the dimmer if they get shorted out
I had the same problem with my mx3 no dash lights and would keep blowing the tail light fuse. the mx3 has the same dimmer switch, theres tons in the junkyards
FC3SDrift is offline   Reply With Quote
